I have for sale hybrid headphone amplifier from CANOR model TP10.
I bought it 1.5 years ago and it’s in pristine condition. I am selling as I am not using it much.
I have all what comes with the amp: box, power supply and manual.
RRP £850
http://www.canor-audio.com/?page_id=77
http://www.canor-audio.com/?p=1491
Headphones are not included.
• The CANOR TP10 is a headphone tube amplifier of hybrid structure, and it is a direct successor to the highly popular and successful SH-1 model.
• The new model has a completely redesigned and improved power supply.
• The amplifier uses superior operational amplifiers (Burr-Brown), and top-echelon polypropylene capacitors.
• Unlike SH-1, the 12AX7 tube is replaced by 12AT7 input tube. ALPS potentiometer is connected to the axis via flexible coupling and a bearing, in order to provide a fine, smooth motion of the knob.
• The front panel is made of 10 mm thick aluminium.
• Input connectors are gold-plated RCA phono plugs. By-pass output is equipped with same connectors.
• The tube amplifier is powered from an external adaptor
• External adaptor significantly increases signal-to-noise ratio which we consider together with musical expression of the amplifier as one of the most important qualities of the amplifier.
• The TP10 can drive dynamic headphones from 30 ohms to 300ohms.
• All tubes are being burned-in and measured on our specially developed BT-2 and TTM-2 measuring devices.
Short link: http://www.adverts.ie/6871500
I am looking for 400 euro but if you are interested I would consider good offer.
PRICE DROP CANOR TP10 hybrid headphone amplifier
- 123.jpg (96.45 KiB) Viewed 1087 times
Re: CANOR TP10 headphone tube amplifier of hybrid structure
Best of luck with sale Maciej it must be very good amp if you choose it over the Cayin HA-1A.
It is like faded memory Tony but I think the Cain was better than Canor or my hearing deteriorated recently. Possible a senior moment? But honestly I found the headphone amp just sitting on the bench and gathering dust, every time I put the headphones on it will take seconds for me to fall asleep.....well the amp is not boring I guess it’s me!tony wrote:Best of luck with sale Maciej it must be very good amp if you choose it over the Cayin HA-1A.
Hehe yes i understand. That seems to be the problem with a headphone amp you really have to either enjoy or need to use it.Maciej wrote: It is like faded memory Tony but I think the Cain was better than Canor or my hearing deteriorated recently. Possible a senior moment? But honestly I found the headphone amp just sitting on the bench and gathering dust, every time I put the headphones on it will take seconds for me to fall asleep.....well the amp is not boring I guess it’s me!
Most of my listening was when our children were young and noise had to be avoided at all costs. I still have a headphone amp but prefer the speakers when I can get away with it. Having said that there is still great enjoyment to be got from headphone listening.
