system audio aura 1
paulb
system audio aura 1
Post by paulb »
Has anybody any experience with the aura 1 speakers?
RichardM
Re: system audio aura 1
Post by RichardM »
Had a pair on demo from Cloney, I thought they were great to be honest. They don't seem to have an active distributor in the UK, so few of the normal magazines and forums reference them. I bought a pair of Dynaudio Excite 14 in the end which are quite a bit more expensive but I thought the System Audios were way better than the B&W 685 S2 which I found boxy by comparison and also the Q Acoustics 2020i which I tried too.
They do need a decent amp, 50W minimum.
There are some good reviews from Canadian mags on the web if you search around.
Good luck with your search!
