2 x 2.5m lengths in white and in excellent condition. Terminated with standard Naim plugs on amp end and banana's at the other.
€100 posted.
Thanks for looking.
Naim NACA5 Speaker Cable
- Sloop John B
Re: Naim NACA5 Speaker Cable
While I don't pretend to fully understand most Naim power amps need 3.5m to ensure a correct impedance value and shorter lengths can actually damage the power amp. Not such an issue with the new all in one's apparently but I'd check the manual just in case.
Apologies I don't want to crap on your thread but would not wants anyone damaging their amp either.
SJB
SJB
Hi SJB,
Thanks for pointing this out, I should have mentioned it myself.
This is the case for the power amps apparently, not sure about the latest ones but the older certainly. It will mean they will run warmer and therefore may shorten the life. Not sure about causing any damage though.
For recent integrated models, 2metres or more is fine. This was used with an XS and the amp always ran cool.
