Record Cleaning Machine
TrickyDicky
Post by TrickyDicky »
Have been looking at investing in one of these recently, and wonder if anyone has any advice they could share?
The HW-16.5 seems to be the business at the budget end, but coming in at about €700 is a significant enough spend for my meagre purse and I don't see any of these coming up on the second-hand market.
Tricky
Re: Record Cleaning Machine
I've only heard good things about the okki nokki machine which I think comes in at <1/2 the price of the HW
bod
Post by bod »
Clearaudio Smart Matrix is far better than the 16.5 (which I had for years). About €500 if memory serves. Cloney stock them too. Good luck with the search! (I think you can get the okki nokki for buttons if prepared to do some woodworking or I may be thinking of some other cleaner from `them across the water` ;-) ).
