I realise this may be sacrilege, but I can't see it as any different to a Gang socket...
Can you buy a single three pin plug with multiple kettle or shaver plugs....
It seems like something somebody would make but I can't find one online at all?
Anyone come across one?
"cat 'o nine tails" power lead?
Re: "cat 'o nine tails" power lead?
Do you mean a single plug with multiple sockets? - well yep, but the easiest way is a 4 gang extension lead? That way they only use 1 length of wire for 4 sockets rather than 4 lengths of wire.
There are computer leads made that are single plug and 2 x IEC sockets (eg 1 plug, 2 IEC plugs 1 for PC and 1 for screen)
Something like this :
http://www.ebay.co.uk/itm/AUDIO-FRIENDL ... 4833c62441
or you can make your own one
http://www.ebay.co.uk/itm/MULTIWAY-MAIN ... 23250088c4 :)
Modest wrote:Something like this :
I knew someone would have seen one! cheers lads!
I've used this crowd before with satisfactory results (ie the stuff worked)
http://www.mains-cables-r-us.co.uk/15-diy-componants
http://www.mains-cables-r-us.co.uk/main ... plug-.html
![Image](http://www.mains-cables-r-us.co.uk/1675-large/hydra-silver-plated-mains-plug-.jpg)
I'm actually looking for the reverse,
Behind the tv is a shambles, I want one plug, with cable to behind equipment, then it'll split off into two kettles and two shavers.....
I have a double IEC lead that only has one plug (to go into the wall). It looks like this:
http://www.ebay.co.uk/itm/Double-UK-Mai ... 1078130262
Can you get multiples? I have no idea.
Nerdcave: ...is no more!
![Sad :(](./images/smilies/icon_e_sad.gif)
Jaybee, this solution will work for you. Simply cut off the existing 13 amp plugtops and fit four cables into this plugtop. Slightly fiddly but doable.Ivor wrote:
Beware of a thin chef!
did you get that on bricks and mortar or online?Diapason wrote:I have a double IEC lead that only has one plug (to go into the wall). It looks like this:
