SA-31 + SP-331 for sale.
Set is 23 months old.
Mint condition, like NEW.
Original boxes.
price 1100e, or 400 pre amp and 700 power amp.
DEMO? -no problem.
http://www.vincent-tac.de/en/product-li ... p-331.html
http://www.audioadvisor.com/prodinfo.asp?number=VISP331
Frequency range: 10 Hz – 20 kHz, +/- 0.5 dB
Nominal output power 8 Ohm: 2 x 150 Watt
Nominal output power 4 Ohm: 2 x 300 Watt
Input sensitivity: 1.2 V
Total harmonic distortion: < 0.1 % max. (1 kHz, 1 Watt)
Signal-to-Noise Ratio: > 90 dB
Input Impedance: 47 kOhm
Inputs: 2 x RCA
Outputs: 4 x 2 speaker terminals
Dimensions: 17" wide, 6.3" high, 17.7" deep
Weight: 41.5 lbs.
http://www.vincent-tac.de/en/product-ty ... sa-31.html
http://www.audioadvisor.com/prodinfo.asp?number=VISA31
Frequency range: 20 Hz – 20 kHz, +/- 0.5 dB
Output voltage: 2 V
Input sensitivity: 150 mV
Input Impedance: 47 k Ohm
Inputs: 6 x RCA
Outputs: 2 x RCA, 1 x Rec Out
Dimensions (W x H x D): 17" wide, 3.1" tall, 11.8" deep
Weight: 9 lbs.
Demo- no prob.
For Sale VINCENT SP-331 power amp + VINCENT SA-31 pre amp
- MooseTrackz
Re: For Sale VINCENT SP-331 power amp + VINCENT SA-31 pre am
Any particular reason why you are selling these?
Hey
Why would you like to change this system after only couple of months?
Guys,
I have upgraded my pre to Vincent SA-31 MK and would like to upgrade power to SP-331 MK.
Regards
Regards
Guys,
Update:
At the moment just pre is for sale, asking price 400e.
Regards
Update:
Regards
