Chaps,
My laptop has blown up, after nearly 5 years of sterling reliable service it has finally died. Graphics chip malfunctioned badly, root cause was the accumulation of dust on the cooling fins which reduced air flow to almost nothing.
When I opened the chassis the accumulation of dust was so bad that at first I thought it was foam packing, it was only when I started to pull at it did it come away in small clumps. I think I should have invested in one of those compressed air tins which one can use to help clear any fluff accumulation. Anyway lesson learned.
So I am currently using a Ipad, I am not too familiar with it, however if there are any Apple users on the forum I am looking for some advice.
I am not able to post images onto the forum threads, all attempts at copying the image from a tab in Safari and pasting it into the comment into the section fails. It just displays the www. address of the image, and not the image itself.
I have tried saving the image, but when I go to paste, nothing is pasted, I have tried copying the image, but again nothing is pasted, I have tried copying the www. address of the image, but again on pasting, the address of the image is pasted, but not the image itself.
There must be a different method to the one I am used to under Windows. If somebody knows please respond as I would be most interested to see how it works.
Cheers in advance.
Using Ipad to post images
Re: Using Ipad to post images
I post all the time from my iPhone....
in safari open the image in a new tab (press and hold with finger on image= right click)
go to the address pane, again press and hold, select all, copy
pop over to tirnahifi
select IMG above and paste the link between the central pair of square brackets...
et voila
et voila
of course not all images can be opened in a new tab...!!
I usually google images search for what I'm looking for....
here's a pic of my speakers
link from google
http://crev.vo.llnwd.net/o42/audiorevie ... 304212.jpg
IMG link from above.... outer square brackets removed
img][/img
with link
img]http://crev.vo.llnwd.net/o42/audiorevie ... 304212.jpg[/img
replace outer square bracket quotes and....,
link from google
img][/img
with link
[img]http://images.search.yahoo.com/images/v ... Tf/IRi8pur[/img]
Hi Jaybee,
Thanks for de info but the above is what I get when I copy the address and paste it between [img]and[/img]
I wonder is it one of de setting on de iPad?
Hi Jaybee,
Ok I copied the image address of your speakers and I was able to post the image.
But why did I get a load of gobble dook the first time, never seen an address that long?
it looks like there are a number of addresses nested in that big long one...
you need to click i for image website and go there...
you've been pasting the search results....
When I hold my finger on a google image it does not open in a new tab, instead it comes up with a option box save or copy.
So I saved the image but when posting the image above nothing was pasted in. Even though I selected paste.
Puzzling?
[imghttp://www.google.ie/search?hl=en&q=thorens%20 ... yyRLv0pZeM:][/img]
Here's a paste of a google image for a thorens TT but again no image
Puzzling?
in google you must click the image you want, click fullsize image in top right, then paste that address...
