Centre and Sub Wanted
For Sale/Wanted
Claus
Post by Claus »
If you see/have something interesting let me know! Thanks!
JFK
Re: Centre and Sub Wanted
Post by JFK »
Hi Claus , Couple of Questions
What will you be using the sub for ? Music /Movies or both ?
Budget ? Size /Colour limitations ?
I have a Gloss white Q acoustics 2070s sub , Both High level and low level connections .. Its very deep on movies and tight with Music or Try BK electronics in the UK , i have a BKXLS 400 DF and its amazing ..
Claus
Post by Claus »
Sub only for the Home Cinema system really. Nothing too fancy but preferably good solid quality. Thanks for your suggestions. Will look into it... :D
JFK
Post by JFK »
Ok , let me know ,No problem if you want to take a loan and try it first ..
Claus
Post by Claus »
The BK subs look brilliant for the money! Not many second hand it seems, but I might fork out for a new one... Will keep looking. I take it your Q Acoustic is not for sale, JFK? Cheers...
JFK
Post by JFK »
Hi Claus , afraid not but Richer sounds Belfast might have one as they were selling them last week ..
Or there is a BK XLS400 for sale here ..http://www.avforums.com/forums/speaker- ... black.html
I am expecting a call back from Richer sounds as i was getting an amp for my Brother , so i asked them if they had any more of the 2070s on offer , i will ping you as soon as he comes back to me ok ..
John
JFK
Post by JFK »
Hi Claus .. PM sent
Claus
Post by Claus »
Thanks so much for your help. That is very kind of you John!
I am now a bit torn between going for the BK 200xls or the Q 2070s. The colour wouldn't matter as it will be hidden in a corner... well away from... wife... ;)
Cheers,
Claus
JFK
Post by JFK »
No Problem Claus your very welcome , i tried the 2070s in place of my resident BKXLS400 and i have to say it did fair pretty well ..
I guess the only issue with BK is that you dont get to try them out , but i have to say that my one surpassed all my expectations ..
Let me know if you would like to try the 2070s , im sure we could sort something
John
Claus
Post by Claus »
Trying it would be very interesting. I will PM you about this! :D
Just to explain my situation in brief:
I have my PMC DB1+ at the moment doing surround front speaker duty. They are actually for sale but I might hold on to them even after the 1028be arrive as my new main speakers in the (hopefully near) future... I was originally hoping to use the 1028be as fronts but that means playing them in front of the chimney breast and that really did not work with the LFT-8. The soundstage just got too wide and seemed to lose depth. So as a consequence I am keeping the two systems separate, using the DB1 as fronts and my old BW DM303 as surrounds.
Hence the need for a sub and a centre....
If anyone has recommendations for some smart looking wall mounting brackets for the DB1+ I would be delighted to hear from you... I have been looking at official ones but they are really expensive! Thomann.de has a few options as well but it's har to know if they will fit the speakers etc. :)
