You can now embed youtube clips directly on the site!
I thought it might be good to try this on a short term basis at least....
So you can now embed a youtube clip directly in your post and its very easy to do.
When you click to create or edit a post, there is now a new button near the Img/URL/Flash buttons called "youtube". Click on that and then paste in the youtube unique ID between the 2 tags.
Example:
The youtube clip url is: http://www.youtube.com/watch?v=P8UCOBajM9o
You click the youtube tags and you see:
youtube][/youtube] (I removed one of the sq brackets to show the code)
Paste the end part of the youtube link - the bit after the equals sign:
youtube]P8UCOBajM9o[/youtube] (I removed one of the sq brackets to show the code)
Enjoy!
Re: You can now embed youtube clips directly on the site!
'Bout time too! ;)
Thanks Fran!!
cool. For the week that's in it....
If we run into bandwidth issues I might have to pull the facility, but hopefully it won't come to that.....
Go forth and post!
Brilliant stuff Fran :)
