lekt player
Re: lekt player
lekt wrote:vocal voice rises up and longer ended..
starting to realize vocal ends a bit too long
iori wrote:Preferred 2.70 s2 for pin point focus and subtle harmonics. Exact location of the vocalist is almost visible. The voice comes from his mouth / body resonance, and not from a wall of sound. Position of each individual vocalist can be clearly reproduced. We are all familiar with human voices :)
try 2.69 s5 for soundstage. maybe better in some ways. only 'size' is massive.
lekt
Re: lekt player
Post by lekt »
uploaded:
lekt.exe1644 v2.71 256
lektshell.exe1644 v2.71 256
used buffer size 256 with other method. try test for playlist, this method not good for control of playlist, this control reduces SQ a bit. if build for single track then SQ is much better.
2 .exe file model is bad for playlist with multi tracks. im trying use in one .exe file. enjoy v2.71, i think soundstage ~ v2.69 s5, but vibration better a bit, vocal maybe good as v2.70 s1?
Re: lekt player
lekt wrote:uploaded:
2 .exe file model is bad for playlist with multi tracks....
playlist seems ok here.
lekt wrote: im trying use in one .exe file. enjoy v2.71, i think soundstage ~ v2.69 s5, but vibration better a bit, vocal maybe good as v2.70 s1?
same free and natural vocal like 2.70 s1.
2.71 more emotion.
2.71 width is very good. height not enough. so soundstage is stretched like rectangle.
2.71 piano better. bass notes good as always. treble notes are improving. like before. strong notes need weaker. weak notes need stronger.
lekt
Re: lekt player
Post by lekt »
jesuscheung wrote: ...2.71 width is very good. height not enough. so soundstage is stretched like rectangle.
right, as rectangle, here's something is not correct. this version have complex code, windows audio likes simple code, hehe... need review this method.
lekt
Re: lekt player
Post by lekt »
uploaded:
lekt.exe1644 v2.72 256
lektshell.exe1644 v2.72 256
improved vibration, correction of soundstage, i feel its sound have good depth, nice rises up. better v2.69 s5?
uploaded:
lekt.exe1644 v2.73 256 1 file
need only one file, call lekt.exe to run player.
test for 1 .exe file model. i preffer this version, feel good with piano, good micro vibration.
try them end enjoy!
Re: lekt player
2.72 is superb! definitely better than 2.69 s5.
new best!
wait a sec.. 2.73? let me listen
Re: lekt player
2.72 and 2.73 are very impressive
have a good feeling that piano will sound really good. let me try...
Re: lekt player
2.72 has very good piano. (not tried 2.73 yet)
lekt, what you changed from 2.71 to 2.72 is the correct direction. keep going!
this is beautiful. perfection will be treble notes to become as good as bass notes.
lekt
Re: lekt player
Post by lekt »
jesuscheung wrote:2.72 has very good piano. (not tried 2.73 yet)
only following your comments, you're excellent sound tester. anything that i has suspect before uploading file, you so soon define and post comments, haha... thanks very much!!
v2.71 method need take care file end and playlist, bad affect to sound. although core isolated/detached from shell but shell affect to sound. weird! v2.72 moves one function to core and balance resource for both processes, good result.
v2.73 1 file need take care open/read source file but doesn't need take care file end and playlist, result even better. not sure, need more test bass weight of v2.73.
Re: lekt player
have some small differences between 2.72 and 2.73.
2.72 has more positive tune.
more transparent? or just thinner than 2.73?
wait. think 2.72 has more micro-details in vocal.
2.73 is rich. soundstage is smaller than 2.72. but has better natural soundstage.
only prefer 2.72 because of better tune
both versions are very similar.
