How would you build your music PC today?
Re: How would you build your music PC today?
check clock output for 1.6v
just to make sure its oscillating
if it is oscillating add another gnd wire from mobo usb header gnd to battery gnd
then try not powering on usb card to make sure its not interfering
nige2000 wrote:check clock output for 1.6v
How can I check the 1.6v clock output? Is that the data wire?
check with multi-meter between clk output and gnd
Clock voltage is 1.2v.
I doubled the aligators and now my PS turned on, but clock voltage is still 1.2v and PC is like dead!
I still have 3.3v coming from bateries.
I tried another aligator from mobo ground to bateries ground and I turned of the usb card, but nothing changes
long shot
look closely at the clock is the a black dot on one of the corners?
Which one ?
clk voltage should be more than 1.2v
nige2000 wrote:long shot
Which one ?
No black dot! Did you put the dot in the package?!!! :)
Wait......found it!!!! Its on the data corner.
Which one ?
you are joking!!!!
clks upsidedown
Upsidedownd?!
Did I conected wrong?
sima66 wrote:Upsidedownd?!
nope my fault
hopefully its not dead
so 3.3v is actually gnd and what was gnd is 3.3v and clk output is the unused one
Now I smoked mobo!!!!
Jeeessssss........
