Did you cut the end on the DC cable, or you made you own?Sligolad wrote:I have way more amps than i need on each rail so I just use terminal blocks inside the Audio PC and run SSD connectors and Molex connectors from these terminal blocks.
One of the 5v lines also powers a DC to DC reg for 1.3v out to the RAM (16Gb) and it has been like that for over a year starting and running fine.
For the cost of the PH supplies you might expect special delivery options :-))
If you have any picture that shows those terminal blocks?
BTW, I hope that, by the time PS will arrive, the delivery bikini girl, will not be just another lady from retirement home!! :)
