Fran wrote:Pearse/all,
I'm happy to bring my "zuma" along if its any good to anyone to try out for streaming?
Nigel: that PSU from Maplin with the 2 outputs won't do as its up to 2.5A and the zuma draws more....
was actually thinking about along with my maplin to power the usb3 and the cpu/or motherboard,
actually just bought the other one should be fit do do the lot (bit overkill i know)
where to inject the usb3 + 5v is annoying me as i have not found a easy solution yet. think im going to try to get it onto the female socket on the board. its been a pain in the ass.
dont think im doing it in vain as i think there's another lift in it for me with my weird adapter, lucky my usb3 card is only 8 euro delivered as i may break it
Been swapping back and forth between Tony's Maplin 12v supply and the Teddy Pardo 12v supply this evening and can not find any difference between the two so it looks like prudence has come up trumps on the power supply front.
Once Tony gets his Zuma together we should all bring along our boxes as Fran suggested and go for a full on streaming session with enough ears to see if there is an improvement with 2 dedicated PC's.
Sligolad wrote:Been swapping back and forth between Tony's Maplin 12v supply and the Teddy Pardo 12v supply this evening and can not find any difference between the two so it looks like prudence has come up trumps on the power supply front.
you should have hit the classified section before you posted that,
think ive got another lift in SQ
don't laugh at my soldering capabilities
if anyone has a better idea how to do this let me know, its too messy to be practical
its a testing exercise but i don't know ill do it in the final build (if there will ever be one)
I ordered up a cable to run from the motherboard header to some sockets. This will open up a new pair of usb3 slots.
I couldn't use the ones nigel posted earlier, wouldn't fit in the case(case height). Nigel, what supply are you using for the +5V?
Fran wrote:I ordered up a cable to run from the motherboard header to some sockets. This will open up a new pair of usb3 slots.
im using this smps till i get my tri linear which i hope will be better or ill have a expensive door stop
http://www.maplin.co.uk/ac-dc-multi-vol ... pply-46107
which cable i you get?
yea it was stupid of me to suggest them adapters obviously wasn't thinking
nige2000 wrote:you should have hit the classified section before you posted that,
Not an option Nige, my conscience would bother me too much!
What's the second USB connection in the pictures, I know one of the sticks is the Win8 on a stick but what's the other one?
I expect there are members looking in here now thinking we have gone off the deep end with all the pics of wires and bits with cryptic notes attached.....maybe we have but it is all worth it!
Pearse, rest assured I think you're all mad anyway. The thread hasn't changed that!
was only joking about the classified section, i couldn't do it either
both are full usb3 connections, the second one is music storage for single pc mode
we are well off the deep end, but you cant get this sort of audio pc quality without spending a lot of money,
once we have figured out the crucial parts and modifications we can get working on lower cost versions without loosing any sound quality
This one:
http://www.ebay.ie/itm/310636569009?ssP ... 594wt_1037
I chose it as it was the shortest one I could find. I may also be able to open one of the cables and isolate the +5v if I build a new supply for it.
Fran wrote:This one:
looks to be as good as it gets was looking at them before
i was thinking if that header plug would come apart without damage it would good place to sever the +5 from the motherboard and add in the external +5
