Guess tthe LP
Re: Guess tthe LP
Someone's gotta do it ;-)
Re: Guess tthe LP
ImageNo 1.
Re: Guess tthe LP
jadarin wrote:ImageNo 1.
Ah! So that's where you're hiding ;-) Well done jad and welcome back. The rest should be easy so.....
Re: Guess tthe LP
ImageNo 4.
Thanks Cybot.I don't know about the last two been easy!!
Re: Guess tthe LP
jadarin wrote:ImageNo 4.
Well done you! Two down. Two to go. You know you can do it :-) Shout for another clue if you need it. BTW the hardest one is the second one. Found it the other day and can't quite believe I actually had it!
Re: Guess tthe LP
cybot wrote:Some clues for the rest:
Committed Dublin Soulster. The dog's even better looking ;-)
As quiet as the Desert now the Captain's not around.....
Re: Guess tthe LP
Never without the clue! I was thinking of Countdown to Ecstasy back cover!
Re: Guess tthe LP
I was hoping you'd get that one Johnny! Well done young man :-)
Re: Guess tthe LP
ImageNo 3.
Re: Guess tthe LP
jadarin wrote:ImageNo 3.
That was the hardest one! Well done Jad, 3 out of four :-)
