2.66 sse2 intel dqa dqa 2cl, and 2.66 sse2 intel dqa dqa, emphasize the leading edge of notes and have an upward tonal slant. 2.66 sse2 intel dqa dqa 2c does not have the midrange clarity of 2.66 sse2 intel dqa dqa 2cl mfence.
mfence is very clear, and does not over emphasize the leading edge of notes.
By getting rid of the over emphasis, you have also gotten rid of the upward (treble) tonal slant.
This is a very nice version. Well done!
this 2.66 sse2 intel dqa dqa 2cl mfence is easily the best of all SSE2 versions. the vibration is recent best! maybe all time best. sounds very correct.
notes fade slower or last longer in the air in sse4. if this can be integrated into sse2, it will be amazing.
Been out of the country for a few days and just jumped straight to 2.66 sse2 intel dqa dqa 2cl mfence.
This is just what I have been after and will be my new reference, the midrange is now lovely and full again with great lowrange power and definition while still having that MQN signature clean (less noise I assume) detail and separation.
The "poison gas" is also still there (see JC comment) :-)
Whatever has happened while I was away MQN now sounds very close to a finished article to me, maybe the JK convertor has helped!
Will try some of the sse4 versions later but this sse2 version sounds amazing.
Cheers, Pearse.
___________________________________________ Nagra HD DAC X, Gryphon Essence Mono's & Pre Amp, Wilson Alexia 2 Speakers,VPI Scout 2 & Supatrac arm, Studer A80 & A812 R2R, Doshi Evolution Tape Pre.
i agree that theres a reduction of soundstage with this 2.66 sse2 dqa dqa compared to the best of the sse4's
On my destop system I have no optimisations at the moment. Apart from disabling the HPET and System Timer discussed yesterday.
It is running a 2012 in GUI mode.
On my main system I have run CAD's optimisation script as adapted for 2012 by Pearse.
did you try phils script then decide other ways are better?
No, after running Phil's scripts I could stop playback of MQn. The control-program wouldn't respond to pressing 'X'.
I believe that was already a known effect of the services stopped by Phil's script.
So I just decided for the moment to let it be and try CAD's script which also disables and reconfigures a lot of items.
I think later the MQn interface might be changed a bit to offer a more 'stable' control under all the optimisation scripts.
sorry for hounding
suppose i really should get to the point
which is better cad script or audiophils?
Hi Aleg, I just made a small change in Scott's script and replaced it in the dropbox link on the Build an Audio PC Thread.
I changed the screen disable to leave on permanently now as with HiRez playback it was going off after a minute but something was kicking it back in a minute later and upsetting MQN playback with sound getting distorted.
Just rerun the script if you are having any issues and it will leave the screen on permanently.
No issues with MQN 16 44 playback on the earlier version though.
Have you tried 2.66 sse2 intel dqa dqa 2cl mfence yet, sounds wonderful here.
Cheers, Pearse.
I started my MQN listening with 2.52 sse2 and I was very impressed but I was limited by my older processor to sse2 versions, so I ripped out the motherboard and cpu and replaced them with Haswell i3. I was able to enjoy the different sse4 versions . Now I find the 2.66 sse2 intel dqa dqa 2cl mfence version is the best so far. Detail is better than the other sse4 versions. Excellent sound.
have fixed that by using a new command in mqncontrol, but haven't released it
have uploaded a 2.68 sse2 intel version, was messing about last night and came up with this version which I think is pretty good. Has a new way of prefetching the data.
sorry for hounding
Sorry to have to disappoint you, but I don't know (yet) as I haven't used Phil's script with MQn much really.
Sligolad wrote:Hi Aleg, I just made a small change in Scott's script and replaced it in the dropbox link on the Build an Audio PC Thread.
Cheers, Pearse.
Hi Pearse
Thanks for chiming in, I believe it is just that script that I'm now using.
I'm not having issues with any resolution, so it probably is that one.
With regard to 2.66 sse2 intel dqa dqa 2cl mfence, I am listening to it right now and I'm very satisfied with the sound. I haven't compared it with the best of SSE4 though.
What I'm not sure of yet is whether SSE2 gives me the same level of texture in the sound (microdetails) as SSE4, and also have not yet made up my mind if I would actually prefer that as SSE2 mfence is sounding so great ;-).
sbgk wrote:No, after running Phil's scripts I could stop playback of MQn. The control-program wouldn't respond to pressing 'X'.
Sbgk
Could you upload that fixed control program?
I would make it a bit more convenient for me to use AudioPhil's script as well in tests.
