probably the best usb to i2s device
Re: probably the best usb to i2s device
wushuliu wrote:
nige2000 wrote:
wushuliu wrote:Someone on another forum wants to know if a flip flop setup would work going from i2s to spdif...
have you a link so i get the context?
should function at least
At head-fi. They want to take i2s from a Singxer F1 usb to i2s/spdif converter and use a wm8804 to convert... Seems plausible
http://www.head-fi.org/t/829639/usb-str ... -for-me/90
yea not sure them guys are used to soldering much,
11/10 for enthusiasm though
their signal path looks really long :(
id guess the newer xmos chips should be better than f1
someone stated the diyinhk dixo pro was better for him there too
i guess under the hood it's the same as the new green 384khz 216 chip board at diyinhk
i see here spdif can be reclocked by a 74 flip flop
http://www.tnt-audio.com/clinica/spd_reclock_e.html
so id be trying that first
its kinda simpler when everythings i2s
modding the f1 might not be as exciting
Bmxmen
Post by Bmxmen »
Hello. O have an amanero usb. It will be better to change it for New 768xmos usb?
https://www.diyinhk.com/shop/audio-kits ... d-pcb.html buy it with Fifo reclocer or put potato chip? Please help me. Thank You much. PS on few Days want to change al Power suply for lifepo4 baterry, it is Good idea to Connect xmos to?
Bmxmen
Post by Bmxmen »
I have see n that i can Bay xmos with or without isolation,what will be better for soekris dac? Where wr have isolated wersion with Fifo reclocer we dont need potato flip flop chip?
randytsuch
Post by randytsuch »
Bmxmen wrote: Sat Sep 08, 2018 7:05 pm I have see n that i can Bay xmos with or without isolation,what will be better for soekris dac? Where wr have isolated wersion with Fifo reclocer we dont need potato flip flop chip?
On my setup, I don't have isolation, I actually removed the isolators on the soekris dac.
I have the diyinhk usb to i2s board, then a potato FF and then the dac. The FF is as close as possible to the DAC i2s connector pins, to make the wiring after the FF as short as possible.
This works well if your PC and USB board are also tweaked, to provide a relatively clean usb signal.
At least that's what I used to have, I converted to a sd card player which is described in other threads on this forum.
Randy
Bmxmen
Post by Bmxmen »
Very thanks! Potato chip is same as Fifo reclocer from diyinhk page? Or mayby reclocer will be better than potato?from where i can Bay pcb for This chip? For Now i have liifepo4 3.3cels, and searching for Good charger with LCD for them.
randytsuch
Not sure that diyinhk did for a reclocker, but based on the potato specs, pretty hard to beat.
https://sites.google.com/view/randy-aud ... /sd-player
Here is my writeup for modding the SDP.
I stuck a potato on this board, you can look at what I did there
The end of this has what I did for the diyinhk board
http://randytsuch-audio.blogspot.com/20 ... dding.html
Bmxmen
Post by Bmxmen »
Hi have any ony try it that fifo reclocer from diyinhk https://www.diyinhk.com/shop/audio-kits ... nator.html works same like potato chip? And if i use fifo reclocer it is good idea to disolder i2s isolators from soekris dam1021 dac? And last one if i will disoldered isolator i dont need 3.3v power suply for isolation site? Very thanks!
