So I did a couple experiments over the last few days.sima66 wrote:Tony,
My "new" battery power supply is not working - DEAD and is out my abilities to fix it or to find the problem! The cable length are the list of my problems!
My ONLY power supply that I'm using now is the ATX Teradak with the longer DC wires that cannot be shorter. So, if there is a way to minimize the "wires length negative effect", I might be interested in that!
I have a Silverstone PCIE to USB card. My USB card is isolated from normal PC power, and powered from a simple 3.3V regulator. I feed the 3.3V regulator with 5VDC from another linear regulator. I had a Jensen 4 pole on the output of the 5V regulator, so it was also on the input to the 3.3V regulator. I removed this cap, and liked it better without the cap.
So I was wondering if the Jensen's were helping?
In my PC, 12VDC is supplied by an external Astron linear power supply. There is probably 12 inches of wire between the power supply and the motherboard connector. I have a Jensen on the 12V line which goes to the 4 pin ATX connector. I removed the Jensen and listened. Definitely worse without the Jensen. So I added this Jensen back, and it was better again.
I have other Jensen's on the 3.3V, 5V and 12V feeds to the 24 pin ATX connector that I want to experiment with, and see if they make a difference.
So my take on this is that in my system, in the right place they make a difference, but I need to experiment more and not just put them everywhere. BTW, in my system, I have simple linear power supplies I made for the 3.3 and 5V, and the Astron for 12V. I have some small AA type LIFEPO4 batteries on the 5V line, but no other batteries in the PC at this time.
But in Canada, from Parts Connexion, a 10,000uf Jensen 4 pole will cost close to $70, and at that price I have a hard time saying to try it and see what happens. I bought my Jensens a long time ago for a much lower price.
Randy
