Aleg wrote:
sbgk wrote:building on v217, v219 is more free flowing, sounds good with jazz, anyway.
Get an application error with mqnloader v73 at instruction 0x4000103b referencing 0x09d87000 memory could not be written. Only loads first track.
Is on win 2012r2
With loader v75, same error on same instruction but different memory location (but also loading different tracks).
fixed track issue v93/v76
elaprince
Post by elaprince »
Is on win 2012r2
Gordon sounds awesome v78 no problem with tracks and albums anymore
Thank you
uploaded mqnrewrite haswell v2
need to create a directory called mqnrewrite and mqnrewrite\out
open a cmd window
cd \
md mqnrewrite
cd mqnrewrite
md out
close the window
copy mqnrewrite.exe to mqnrewrite
copy the track you want to rewrite to mqnrewrite directory
rename it to test.wav
double click on mqnrewrite
wait until process has finished
rewritten test.wav file will be in the out directory
play as usual
I think there is an improvement, not sure whether to incorporate it in mqn or make it standalone.
would be quite easy to have a batch process to copy/rename/rewrite/rename in a loop
not suitable for copying other types of files because it misses a few bytes off the end.
minionas
Post by minionas »
I feel it as improvement: better definition, i can feel space better, microdinamics improved.
minionas wrote:I feel it as improvement: better definition, i can feel space better, microdinamics improved.
been through a few iterations, a few things were incorrect.
v4 is a bit better.
difficult to believe that it is making a difference.
uploaded mqnrewrite.bat
copy it to c:\mqnrewrite
also copy paste.exe to c:\mqnrewrite (it's in the same folder as mqn.bat eg c:\musicplayer or can be downloaded)
then just use it like mqn ie copy files or folder to the clipboard and double click on mqnrewrite.bat
the rewritten files will be in the c:\mqnrewrite\out folder
don't delete your original source files as the rewritten files are a few bytes smaller, I'll fix that sometime.
tried rewriting an already rewritten file and sounds different again. If it's better I'll alter mqnrewrite.bat to rewrite twice, worth a try.
seems to take a bit of edge/treble away, not sure that's a good thing. Some tracks sound better than others.
elaprince
Post by elaprince »
Gordon I can only rewrite one file even if I click 2 or 3 file it only gets me one test.wav
Also it ends up in mqnrewrite folder
Problem is I cant make mqnrewrite\out folder it will not allow me to use that slash \
Any suggestion?
Thank you
minionas
Post by minionas »
You just create a 'out' folder inside 'mqnrewrite' folder.
Slash is just for catalogue hierarchy separation..it is not used in names..
elaprince
Post by elaprince »
minionas wrote:You just create a 'out' folder inside 'mqnrewrite' folder.
Thank you
That explain why I could not get it to work
Did you try more then 1 track?
Seems like only 1 track can be rewritten
minionas
Post by minionas »
You had no 'out' folder therefore you weren't getting multiple files rewritten inside it..
Here it is working as supposed.
