janh
Post by janh »
elaprince wrote:Gordon everything working perfect no glitches
Sound superb on my setup
+1
A big thanks for your work!
Could be time to make a guide for new users, to put with your downloads.
Jan H.
darkpink
Post by darkpink »
+1
Jan H.
+1
uploaded play v137, just a few tweaks, think it makes a difference.
elaprince
Post by elaprince »
And when you thought Gordon was done with it
Thank you
Appreciate all your hard work
elaprince wrote:And when you thought Gordon was done with it
Thank you
there's a few more things I'd like to try to get working. Don't know if this version has gone too soft or whether it's my hearing. Detail seems ok.
adolfo.a.aguiar
Post by adolfo.a.aguiar »
MQn does not work for me with 10ms buffer. Could someone upload mqnplay v134, which I believe is tha latest with larger buffer? Couldn´t find it in the Archive.
Thanks.
Last edited by adolfo.a.aguiar on Wed Nov 11, 2015 6:16 pm, edited 1 time in total.
elaprince
Post by elaprince »
Anyone compare v137 to v136 yet??
I am out of town till weekend so can't try it ,hopefully when I get back
Gordon mention it could be on the soft side
janh
Post by janh »
Listened a little to mqnplay v136 and v137.
I clearly prefer v136. It has clearity and purity of tone.
v137 has too much reverb or something added.
Jan H.
EDIT
Listening more, i think I rate them more even, can also slightly prefer 137. Need some time to change.
adolfo.a.aguiar
adolfo.a.aguiar wrote:MQn does not work for me with 10ms buffer. Could someone upload mqnplay v134, which I believe is tha latest with larger buffer. Couldn´t find it in the Archive.
Thanks.
Thanks, Gordon.
uploaded control v52 and play v138 - works for win 8.1/w2012 r2 and win 10
just trying some things and wondered if it works ok.
