uploaded v113, should work for everyone, a bit more sustain with this one, assuming that's a good thing.
elaprince
Post by elaprince »
Welcome back Gordon
Everyone missed you
Can you tell why v111 and v112 doesnt work with with Thesycon driver?
What is different to v113?
elaprince wrote:Welcome back Gordon
Everyone missed you
think it was the waveformat issue which I mentioned, some drivers won't accept 16/44 in described in waveformatextensible. waveformatextensible is used for hirez > 16 bit formats, but can also be used for 16/44.
v113 has different code to previous versions, just something I was trying, seems to work.
v114 less thin sounding, more musical.
v116 might be better.
elaprince
Post by elaprince »
Gordon somehow v116 is messed up I think
Will give more listening but so far I dont like it
I have compared it to v106 and v109 which I like both versions
Thank you
elaprince wrote:Gordon somehow v116 is messed up I think
Thank you
yes, 116 not that good, 117 any better ?
elaprince
Post by elaprince »
V117 new reference I think
Really good
Like it very much
janh
Post by janh »
elaprince wrote:V117 new reference I think
Really good
Like it very much
+1
uploaded v118 and control 31, v118 requires control 31 to work.
just a rough draft version as think there is quite an improvement in sq. Playback starts after load has finished, but will try to get round that.
seems to have improved clarity and authority, the proverbial veil has been lifted.
shall tune the sound further, but it's already the closest I've been to the music.
looks like control goes up to 30% cpu, shall have a look at that.
elaprince
Post by elaprince »
control v31 and mqnplay v118 CPU goes up to 25% and no sound
I waited for at least a minute and still no sound
Went back to control v30 and Mqnplay v117 everything works
Anything I am doing wrong?
Thank you
elaprince wrote:control v31 and mqnplay v118 CPU goes up to 25% and no sound
Thank you
was mqnloader finished, I guess so if control used 25% cpu, don't know. shall check.
uploaded v119, but couldn't see anything that should stop it working. did you have the right version of v118 ?
