elaprince
Post by elaprince »
I think I prefer v106 better then v96
will need to do more listening tonight
janh
Post by janh »
janh wrote:Yes, here seems like all small files <=27 Mb will not play in a singeltrack playlist,
With control v30 there is no longer this problem.
uploaded play v107, exactly same instructions as v96, just different alignment. quite like it. doesn't have the strident quality of recent versions, has more punch, but retains the open detail of v96.
elaprince wrote:something is stopping Mqnplay from closing when music stops on my setup
only think I can think of is if control is not set to start as administrator and therefore can't shutdown play.
play, loader and control should all be set to start as administrator.
elaprince
Post by elaprince »
Yes all are set to start as administrator
I have Fidelizer running and Lasso
Maybe one of them I will have to check that
Thanks Gordon
elaprince
Post by elaprince »
Still same Gordon
control is running in task manager when music start then closes but Mqnplay still runs and CPU goes high
Also CMD window of control open with music playing with other controls it was close as soon as music starts
Maybe there is something on my setup maybe next control will fix that?
Anyway v107 really sounds good
uploaded play v108, going to go out on a limb and say this is the best version there has been. stunning detail, what more do you want ?
another tip from agner fog so don't need single byte alignment instructions.
I take no responsibility for loss of hearing or blown speakers as the natural response to this version is to play the music very loud.
elaprince wrote:Still same Gordon
does the taskkill command in mqn.bat close it down ?
create a .bat file with taskkill /f /im mqnplay.exe
and see if that works .
elaprince
Post by elaprince »
If you dont mind can you post it please ?
Thank you
elaprince wrote:If you dont mind can you post it please ?
Thank you
uploaded 2 versions of mqnstop.bat, do they work ?
