minionas wrote:V69 < V71 imho. Noticeable since first seconds. It just makes picture bit more alive with better note edges with help of more trebble energy, though not even close to bright sound!
do you mean v69 is less good than v71 ?
think v73 loses the treble again, v72 sounds better, strange these registers having a sound.
minionas
Post by minionas »
Yes. 71 is better to me. Though difference is slight. Would be totally happy with either.
Ill see about 72 and 73.
sbgk wrote:...
only problem now is all the distracting noises in the background, nails scratching on strings and breathing etc that I can hear, is this hifi ?
If it is in the recording you should be allowed to hear it and not have it masked ;-)
V73 is sounding wonderful, love it.
Shall also listen to V72 later.
Aleg wrote:
sbgk wrote:...
I found v73 was a bit lacking in treble.
v74 is worth listening to. yup, think this one will do, no more things to try, just short of a couple of registers.
elaprince
Post by elaprince »
Waiting for my system to warmup
Will give it a go soon
Multitrack would be useful Gordon
sbgk wrote:
Aleg wrote:
sbgk wrote:...
I find v74 a bit too sharp and dry in the high frequencies.
I would prefer the v73. It is a bit rolled off in the top end, but more naturally balanced on my setup.
v75 is v74 with v73 tweak, so maybe more to your liking
elaprince
Post by elaprince »
Gordon seems like you really did it with v75
Exceptional balance,base and details unimaginable from any player
If you think you can tweak it even more go ahead as for me I would be very ,very happy with this version
Thank you
janh
Post by janh »
Listened to v73, 74 and 75.
v74 has a slight veil.
Both the other two are fine. (I think) I prefer v73, it make the music sing, like Aleg I "love it".
The lack of treble in v73 - my old ears do not register that much.
sbgk wrote:v75 is v74 with v73 tweak, so maybe more to your liking
V75 is indeed much more to my liking than v74
