Berlioz:
Les nuits d'ete
Le Corsaire Overture
Le Carnaval romain Overture
Le Roi Lear Overture
Hungarian March
BBC Phil/ Vassily Sinaisky
Katarina Karneus (Mezzo)
Jared wrote:
I will be spending a few days recapping on a few of my Berlioz recordings, which haven't seen the light of day in some time.
Jared, do you have this?
It is superb.
It is superb.
I only have the Requiem, Sean.... I have the Colin Davis 6CD set of Orchestral Works, which is also great.
Vinyl....
jaybee
Post by jaybee »
..... and I give up, I can't, no matter how often I try it, warm to Bach's masses.... they leave me cold....
I don't doubt the genius, but it does nothing for me ( unlike the solo cello and violin works )
Jared wrote:Berlioz:
Les nuits d'ete
Hungarian March
another listen, in preparation for the arrival of Susan Graham's version...
jaybee
Post by jaybee »
fergus wrote:Vinyl....
ditto....but on cd
jaybee wrote:http://cdn.7static.com/static/img/sleev ... 31_500.jpg
hmm... if the mass in B minor doesn't move you... :-/
tell you what, put it to one side for a couple of years, and let it collect a bit of dust. This is what I did with a couple of disks which I really struggled with very early on, but came back to them 3 years later to find them very pleasurable... you might find the same.
in the mean time, have a listen to some other Germanic baroque choral works, like Buxtehude's fabulous 'Membra Jesu Nostri' or some Biber, and work your way in.
jaybee wrote:ditto....but on cd
I similarly have and love that set....
