uploaded v25 control/loader, copy is now all in assembly code instead of calling an assembly function, which was adding noise.
that's the final sq version, next ones will be functional.
adolfo.a.aguiar
Post by adolfo.a.aguiar »
adolfo.a.aguiar wrote:Does mqnplay v34 require mqnloader ?
I think the versions that work with mqn.bat don't need mqnloader.
How come I can play v34 without mqnloader in the folder?
Most likely explanation is you're not playing from that folder.
just a note about control/loader v25 - it is a big improvement, hearing things I've not heard before and that's on the cheapo headphones and £15 dac, just get absorbed into the music which is as it should be.
check task manager, loader should be running before play starts.
First I would check if all you are trying out, is located in folder c:\musicplayer and not somewhere else!
adolfo.a.aguiar
Yes, just checked.
My MQn.bat was pointing elsewhere.
Sorry for that.
elaprince
Post by elaprince »
Is there anyway to have that music player folder in different place?
What I am trying to do is load win2012 to ram and have MQN folder on my ssd drive and play from there
Is that possible?
I just want to try it and compare
Any suggestions how to do it?
Thank you
elaprince
Post by elaprince »
Thank you Gordon will try editing MQN.bat
Hopefully will works
elaprince
Post by elaprince »
It does not work still looking for c folder even after editing
Can someone help with this please?
Thank you
