Same here Gordon
v34 so far best
I never use MQn in core before and today I switch and it is amazing
I dont think any player out there can match analog sound MQn creates
Well done
Try couple of loaders v19 it is one I pick every time
Thank you
v34 so far best
Well done
Thank you
+1janh wrote:Listened to mqnplay v30 and v34, both with contr/load v19.
Compared to v30, v34 is much better - clarity, purity of tone, colour, more life to the music.
Very enjoyable to listen to v34, thanks sbgk.
Jan H.
v34 is fantastic!
Ubuntu Live USB in RAM
Does mqnplay v34 require mqnloader ?
I think the versions that work with mqn.bat don't need mqnloader.
yes still requires all three parts: mqncontrol, mqnloader and mqnplay.
Not related to mqn.bat or not.
mqncontrol calls mqnloader which calls mqnplay.
I think, you might confound mqnloader.exe and mqnload.exe. The first is needed and is part of Gordons solution. The latter is an alternative to mqn.bat.adolfo.a.aguiar wrote:Does mqnplay v34 require mqnloader ?
sbgk wrote:uploaded v24/v36
Any functional changes?
Sound quality is superb (maybe even better than v34)
screen switch off removed and alignment change in control/loaderAleg wrote:sbgk wrote:uploaded v24/v36
v36 went back to v30 code, thought v34 sounded a bit loose and v36 is more precise (v36 is probably exactly the same as v30)
v30 had 3 instructions (haswell can make them 0 latency) between wait and io and v34 had 5 (which included a memory operation),
so seems 3 is better after all.
