sebna
Post by sebna »
Was listening yesterday to V7. did not do comparisons but it was very impressive. Today will do some comparison. Am I right that the player will always cut off after reaching 50mb mark on the file?
Cheers,
seb
sebna wrote:Was listening yesterday to V7. did not do comparisons but it was very impressive. Today will do some comparison. Am I right that the player will always cut off after reaching 50mb mark on the file?
Cheers,
seb
yes, stops after 50mb
v 8 had a mistake so uploaded v9
I think v7 is better than v9
V9 has become a bit wooly, lost some of its speed in the transients.
Aleg wrote:I think v7 is better than v9
ok v10 is v7 + 1 other change
Much better again.
For those having problems stopping Mqnplay.exe with the taskkill command, check if you have WMI service running or not. taskkill requires WMI-service, but it is an extra service running.
elaprince
Post by elaprince »
Anything new Gordon??
Waiting patiently for new MQn for either Haswell or noo Haswell
Thank you
so the obvious thing to do is load the data into the driver queue and just have mqn pause, uploaded v11 which does this.
mqn is no longer rendering, it loads the data into the device driver queue and sleeps for 4 minutes (it has to keep the device open).
Now everything is in kernel mode and there's a lift in SQ, I think.
You can check mqn processor %, should be 0.
v11 reduced the priority after the load, but sounds better with it kept high, uploaded v12.
Definitely the best I've heard.
TioFrancotirdor
Post by TioFrancotirdor »
sbgk wrote:so the obvious thing to do is load the data into the driver queue and just have mqn pause, uploaded v11 which does this.
v12 works on my setup. CPU usage is around 1%.
Thanks Gordon.
Ubuntu Live USB in RAM
Thanks Gordon.
any comment on the sq ?
has anyone tried something like http://www.softtreetech.com/24x7/archive/50.htm to replace the device name ?
Thanks Gordon.
Both v11 and v12 will not run on my setup on 2012R2.
In taskmanager I see it crash directly after startup.
