Toshiba MOSFETs with a twist
nige2000 wrote: Wed Jul 26, 2017 11:57 am
jkeny wrote: Wed Jul 26, 2017 11:37 am DAC with differential outputs - a differential version of PCM5102
I rewired my Superlux headphones to be differential so no common ground
yea that is what i thought would be optimum
its an awful shame all headphones arent wired differential
Yea, it's not a difficult job to rewire them
I did it on some akg k700 put a 4pin xlr plug on it
Makes a substantial difference
nige2000 wrote: Wed Jul 26, 2017 12:34 pm I did it on some akg k700 put a 4pin xlr plug on it
Yep nice difference even when not driving them balanced.
abraxalito
Post by abraxalito »
Are there any already available at an affordable price which come ready-wired for balanced? My HD668Bs have a TRS 3.5mm connector right beneath the 'left' transducer, looks like that would need swapping out for a TRRS, along with the connecting cable.
abraxalito wrote: Wed Jul 26, 2017 12:53 pm Are there any already available at an affordable price which come ready-wired for balanced? My HD668Bs have a TRS 3.5mm connector right beneath the 'left' transducer, looks like that would need swapping out for a TRRS, along with the connecting cable.
Don't think so at Superlux prices - they tend to be targeted towards 'audiophiles'.
It's a pretty easy mod especially for you. I have each can wired independently with very flexible Belden microphone cable - I haven't put a 4 pin XLR plug on the end as I will probably use a mini-xlr plug & socket
abraxalito
Wendy's having a search on Taobao to see if there's anyone who'll rewire cans as a service. We shall see what shows up....
jkeny wrote: Wed Jul 26, 2017 1:01 pm
yes
mini xlr looks good
http://ie.farnell.com/rean/rt4mp/plug-t ... dp/1813721
http://ie.farnell.com/rean/rt4fc-b/sock ... dp/1813719
is the superlux wired with two gnds one per side or is it common?
abraxalito wrote: Wed Jul 26, 2017 1:40 pm Wendy's having a search on Taobao to see if there's anyone who'll rewire cans as a service. We shall see what shows up....
Wish I had a willing assistant like that :)
nige2000 wrote: Wed Jul 26, 2017 1:59 pm is the superlux wired with two gnds one per side or is it common?
The common ground is disconnected & each side gets it's own ground - wouldn't be differential otherwise
