now rename squeezelite-win.exe to squeezelite-win.exeorig and squeezelite-win.exev17 to squeezelite-win.exe and portaudio_x64.dllv17 to portaudio_x64.dll and restart lmserin wrote:OK, I think I've tried JLP.
I downloaded LMS server.
Installed Local Player by triode.
Put portaudio_x64dllv17 into C:\ProgramData\Squeezebox\Cache\InstalledPlugins\Plugins\LocalPlayer\Bin
Put squeezelite.exev17 into C:\ProgramData\Squeezebox\Cache\InstalledPlugins\Plugins\LocalPlayer\Bin
No audio
stopped server.
Restarted server.
Got audio playing
Selected the KS Option from the Local Player output device.
Played some audio.
Have I done everything correctly?
JLP wdm-ks player
Re: JLP wdm-ks player
Thank you, but still can't manage it to work. (the system cannot find path specified)sbgk wrote: have uploaded start and list devices bat files, start will need your device name, copy it to make ones for other devices
BTW v17 sounds amazing, I'll test it later.
John,
I think you need to edit those .bat files, to insert your exact path to that /bin folder, what could be different than Gordon released.
I haven't tried it yet, but just simply looking into your screen shot.
Gordon, am I meant to have both portaudio.dll and portaudio_x64.dll in the C:\ProgramData\Squeezebox\Cache\InstalledPlugins\Plugins\LocalPlayer\Bin folder?sbgk wrote: now rename squeezelite-win.exe to squeezelite-win.exeorig and squeezelite-win.exev17 to squeezelite-win.exe and portaudio_x64.dllv17 to portaudio_x64.dll and restart lms
When I only had the portaudio_x64.dll file in this folder it threw an error saying I needed portaudio.dll.
Thanks for your help.
Buy locally.
Build locally.
Grow locally.
Share locally.
Buy locally.
Build locally.
Grow locally.
Share locally.
delete squeezelite-win.exe or renameerin wrote:Gordon, am I meant to have both portaudio.dll and portaudio_x64.dll in the C:\ProgramData\Squeezebox\Cache\InstalledPlugins\Plugins\LocalPlayer\Bin folder?sbgk wrote: now rename squeezelite-win.exe to squeezelite-win.exeorig and squeezelite-win.exev17 to squeezelite-win.exe and portaudio_x64.dllv17 to portaudio_x64.dll and restart lms
put in squeezelite-win.exev17 and rename to squeezelite-win.exe (its x64)
your error message comes up because youve got the original squeezelite-win.exe which is x86
got mine working earlier just worked first time dunno what i was at yesterday (slow day)
17 seems better but need more detail/better timing
Tried all ways - no effect.cvrle59 wrote:John,
Remember to stop server before any change.erin wrote:Gordon, am I meant to have both portaudio.dll and portaudio_x64.dll in the C:\ProgramData\Squeezebox\Cache\InstalledPlugins\Plugins\LocalPlayer\Bin folder?sbgk wrote: now rename squeezelite-win.exe to squeezelite-win.exeorig and squeezelite-win.exev17 to squeezelite-win.exe and portaudio_x64.dllv17 to portaudio_x64.dll and restart lms
looks likr you're installed on d drive
The bat files were on D drive. I installed LMS and SL to their default destinations.sbgk wrote:looks likr you're installed on d drive
I have found c:\ProgramData\Squeezebox\prefs\plugin\localplayer.prefs
There is output device stored. I'm trying to use it... will report.
the batch file was incorrect, I was using -b 2000:2000000 and changed it to -b 0:2000000 in the uploaded file
seems the minimum size of -b x:y is 1000 for x
so using -b 1000:2000 works
was trying different sizes of latency, 10 is near 448 samples for 16/44 and 23 is near 1024 samples
also trying latency 10000 and x = 10000, still not sure of x does anything, but the fact there is a minimum size is unexpected, shall turn logging on and check
think max latency is 1000, doesn't sound that good, 500 is ok, changing x seems to have an effect setting to 10000 and it seems longer before the music starts and there is an effect on sq, not sure if it's good, but different sized buffers can affect the noise.
