I'm astounded by the improvement in SQ using the syscall functionality which Lekt helped me with, if I can get the other instruction working it's going to sound unbelievably good.
I've built it for a win 10 build, so not sure it can be used for win 8/8.1 etc as the syscall numbers are different.
No upload yet, but it is very, very good.
you using win 10 preview?sbgk wrote:I'm astounded by the improvement in SQ using the syscall functionality which Lekt helped me with, if I can get the other instruction working it's going to sound unbelievably good.
yes, it's got a start button where you can access the menus and everything. win8.1 was just stupid on a laptop.nige2000 wrote:you using win 10 preview?sbgk wrote:I'm astounded by the improvement in SQ using the syscall functionality which Lekt helped me with, if I can get the other instruction working it's going to sound unbelievably good.
with this new version it's the first time I've been relaxed listening to digital music. So imagine how good it would be with no user to kernel interface. Driver suppliers should provide that option, just pass it the start point of the ram and the driver just plays.
If you are looking for MQnload, this is where Taggart is offering it:tony wrote:Might be one MQNload version there.
https://www.dropbox.com/sh/u71wm4ki02vdvg6/p-DhIcn5L0
Take care
Thomas
had a win 10 install on usb key i must look for it
looked promising too kinda intuitive
Renamed MQN files for MQNLoad here:
https://www.dropbox.com/sh/u4ulm989tf4p ... gRtGa?dl=0
Big thumbs up to you Tony, John Dot and Pearse for uploading your monster libraries - now I have something to play with :)
Windows 8.1 Pro 64bit / Intel i5-4570 3.20GHz 16GB RAM / iFi micro iDSD DAC / Sennheiser HD 580 / Topping TP60 Class T amp / NAD 3080 int. amp / Antique CV 12TR + Acoustic Energy Aegis Evo One speakers
It does work on Server 2012R2, but then that's the equivalent of 8.1.sbgk wrote:uploaded v29 for win8.1 users, can someone try it, not sure if it'll work with win 12 srvr, win8 won't work.
Don't have regular Server 2012 any more.
Great amount of detail any transparancy BTW.
that's good news, thanks for trying.Aleg wrote:It does work on Server 2012R2, but then that's the equivalent of 8.1.sbgk wrote:uploaded v29 for win8.1 users, can someone try it, not sure if it'll work with win 12 srvr, win8 won't work.
the timing seems better, that's what I mean't by it's relaxing to listen to, you can just let the music flow.
