it's at 10msnige2000 wrote:dont think jplay is a good benchmarker for sq maybe more for usabilitysbgk wrote:So JPlay dac link is just using the device driver interrupt to time the swapping of buffers.
With MQn there is no swapping of buffers because there is no copying of data or streaming and it has always used the driver interrupt to time the next buffer.
I tried JPlay 6, but found the 0.5 ms system timer setting to be too digital (why not make this configurable ?), so it is my impression that they equate increased resolution with increased digital noise which is the opposite direction MQn took. If you decrease the buffers then you are just increasing the digital noise because the same instructions are being run more often than with larger buffers, there is no reason for lower latencies, it's not a musical instrument that needs to play sound as soon as a key is pressed.
Too many compromises with JPlay.
but can we not lower the latency even just to 5-10 ms just to see what the guys here think of it
ok how about a 2-5ms thensbgk wrote:it's at 10msnige2000 wrote:dont think jplay is a good benchmarker for sq maybe more for usabilitysbgk wrote:So JPlay dac link is just using the device driver interrupt to time the swapping of buffers.
What about people with device string longer than one in mqnplay file? I took a look and this issue still doesn't seem to be sorted outOctagon wrote:For everyone who wants to try, the way how to do it with some hints in summary:nige2000 wrote:can u upload your working v24 mqn folder please
ive a diyinhk i2s hooked up atm
Create a folder c:/musicplayer
Copy MQncontrol.exe and MQnloader.exe in that folder; at this moment in time you need both as v7.
Hex edit mqnplay.exe, as described by sebna on page 650 of this thread, with your device name, latest versions work all with v7 for example all v2x long device name.
Yep Pearse exhibited and Nigel/Seb went alsoviewtopic.php?f=8&t=2661sbgk wrote:tony wrote:
Gordon did you make it to the show??sbgk wrote: no, was tempted, but couldn't make it in the end. Did you go ?
great effort, didn't realise you would be using MQn, thought you'd all gone over to JPlay 6.tony wrote: Yep Pearse exhibited and Nigel/Seb went alsoviewtopic.php?f=8&t=2661
we weren't using MQn probably would have been better sq wise if we did but for versatility and less complications jplay was usedsbgk wrote:great effort, didn't realise you would be using MQn, thought you'd all gone over to JPlay 6.tony wrote: Yep Pearse exhibited and Nigel/Seb went alsoviewtopic.php?f=8&t=2661
there was a guy using xxhighend sounded good enough to try it out, has anyone here tryed it?
Ah, ok, I preferred your 2014 setup.nige2000 wrote:we weren't using MQn probably would have been better sq wise if we did but for versatility and less complications jplay was usedsbgk wrote:great effort, didn't realise you would be using MQn, thought you'd all gone over to JPlay 6.tony wrote: Yep Pearse exhibited and Nigel/Seb went alsoviewtopic.php?f=8&t=2661
Just trying out Jplay6 it was released yesterday.Sounds good so far. Pearse was using one of the 6 beta's simply as Nigel outlined it made things easy. We should have tried out MQn to see if it would have worked better but the show is hectic and when you get things working ok and the room constantly is filling up with people messing around with versions of anything is the furthest thing from your mind.sbgk wrote:great effort, didn't realise you would be using MQn, thought you'd all gone over to JPlay 6.tony wrote: Yep Pearse exhibited and Nigel/Seb went alsoviewtopic.php?f=8&t=2661
I still use a variety of MQn's at home but have to end up using an old one for any odd resolutions. The latest stuff haven't gone near it.
Really pity you didn't make it over.Not that anybody really understood his pc was probably the most tricked out one they will ever hear.
But even allowing for that the room had a huge impact on what sound was being produced. We needed Simon to pull up with every GIK bass trap he has to try and tame that room.
2015 set up was only different in that it had a better pc and the Lampizator Dac. Amps,Speakers,pre were the sam
all jokes aside the system has sounded a good bit better than it did at scalford 2015, it should have been a country mile ahead of anything elsesbgk wrote:Ah, ok, I preferred your 2014 setup.nige2000 wrote:we weren't using MQn probably would have been better sq wise if we did but for versatility and less complications jplay was usedsbgk wrote:
we weren't overly impressed with it sat night, luckily pearse put some cushions etc behind the speakers sun morning which helped
i guess we're going to blame the room for it not been at its best but it still sounded excellent
