Any new versions or extension (multiple sample rates?) forthcoming?
laptop speaker?
testing would be impossible
I couldn't even on my second system
z87n wifi std atx supply arcam rpac yamaha as500 mission m33i
if the test was does it work ? then it's not a problem, apart from I can't get it to work. It works with portaudio, so just need to find what's different.nige2000 wrote:laptop speaker?
Looking forward to any new version to trysbgk wrote:if the test was does it work ? then it's not a problem, apart from I can't get it to work. It works with portaudio, so just need to find what's different.nige2000 wrote:laptop speaker?
Any word on the auto device discovery?
I thought this functionality was on its way?
They both sound very good.sbgk wrote:got one of the lower level instructions working, have v8 and v9 aleg versions of mqnplay, any preference ?Aleg wrote: Looking forward to any new version to try
I have a preference for v9, which sounds more involving.
V8 is a bit more lean and more 'polite', v9 grabs you a bit more by the collar.
Detail is good in both.
Like the new development.
that's what I found, but good to get some confirmation. Shall try and get the second function working.Aleg wrote:They both sound very good.sbgk wrote:got one of the lower level instructions working, have v8 and v9 aleg versions of mqnplay, any preference ?Aleg wrote: Looking forward to any new version to try
