sbgk wrote:There seem to be a number of reclocking and usb improvement devices which should reduce jitter eg the schiit wyrd, ifi gemini cable, purifier etc.
For reclockers you should check out the Mutec products like MC-3.1 and esp. the new MC3.1+USB which will appear soon / in a couple of months.
Hi,
I am waiting for the MC3+ USB reclocker/asynchronos USB device and will make it work with MQn. Gonna post the experience as soon as possible, but the availability of the device will still take some time ;)
Take care
Thomas
Need some help:
I have my first (PPA'd) Haswell-PC running, Server2012 R2 GUI.
I put the three exe-files from Febr.11, plus a test.wav into a folder c:\Musicplayer. I also had my device-id from mqndevinfo, and inserted into mqnplay.exe, using sebna's method.
To play I double-clicked on mqncontrol. Then not much happened. The mqncontrol-window was empty and after a few seconds was a message: mqnloader.exe has stopped working.
Something is wrong, any idea?
janh wrote:To play I double-clicked on mqncontrol. Then not much happened. The mqncontrol-window was empty and after a few seconds was a message: mqnloader.exe has stopped working.
Hi Janh,
Difficult to say because there are many possibilities of mistakes. Just think about the hexediting...
I suggest you start first getting one of the last not individual MQn versions playing. That will show you wether the whole system works or not. If that is the case, try again with KS Beta.
Just a guess: In general the audio service is switched off in R2, you need to switch it on to make the wasapi versions working. In case you use AO, AO will do that for you after(!) AO optimization.
Good luck
Thomas
Thank you Thomas!
No AO yet.
At present I can play music with MQn Normal control and play.
With Avx2, I can play with Control 4.02 and Play 8.86. But I can not play with Control 4.25 and Play 9.12. Can well see the difference in Task Manager in these two cases.
I have only tried these two cases so far. The earlier versions are just randomly taken. Any earlier Avx2-versions to recommend?
janh wrote:But I can not play with Control 4.25 and Play 9.12. Can well see the difference in Task Manager in these two cases.
Hi Janh,
Great to hear you have MQn playing!
4.25 & 9.12 are bundled and will only play together, I can' t comment on them as my device name is to long to hexedit them.
Try mqncontrol 3.92 avx2 with mqnplay 9.00 avx2 oct hexedited for your device. That is the last individual version I could do for my device and playing pretty well. If that will work you should get the test version from February working as well.
Enjoy
Thomas
