So one does need to use .bat? I had no luck with it since I thought MQnloader was similar to MQnload as far as functionality.Octagon wrote:nige2000 wrote:pardon my ignorance
I do use Tasker in the same way I did before and it works fine. I start the .bat manually which I start in the other versions via MQnload.
Take care
Thomas
64bit xp was troublerickmcinnis wrote:nige2000,
That is why I asked if a 32 bits version would be possible,
Troublesome in which ways? My experience with XP was very good.
Is it not capable of using kernel streaming properly? When I used it it was with JULI@ soundcard and ASIO.
My curiosity has the best of me.
anyhow win 8.1 r2 is just natively better at audio
juli@ might not do ks
I'm only curious to what pci direct will sound like
I'm still stuggling to leave wasapi yet
can someone upload a MQN bat file that works with tasker and new mqn please
what's the purpose of the new MQNloader?
Thomas can you upload your favourite MQN version folder please
just Trying to get up to speed
Hi Nige,nige2000 wrote:can someone upload a MQN bat file that works with tasker and new mqn please
I guess you are talking about taggerts MQnload? It makes it easier to change different MQn versions, includes a shortcut to play highlighted files and offers a command line which works everytime you start a file with MQnload. I use this command line to start a .bat which sorts the core usage and task prioritisation via Tasker, another great tool of Taggert.
My favorite so far is MQncontrol 3.92 avx2 with MQnplay 9.00 avx2 oct. Gordon built this oct Version for my FireFace UCX. I could not test the newer versions as my device name has 94 digits and there are only 90 available to be hexedited. As the February 11 test versions have 104 digits I was able to change them.nige2000 wrote:Thomas can you upload your favourite MQN version folder please
Nige, send me your mail via PN and I send you what you need.
Take care
Thomas
new version of jplay out for beta testing, could it be the version that stops mqn ?
the problem with jplay is that I've always found it a bit digital, but shall give it a try.
they say it no longer uses the pc clock and gets it's timing from the dac, don't know what this means, it's beyond me.
I thought the driver told the pc when it wanted more data, so don't understand the change in clock they are talking about.
Had an initial blast at the new Jplay beta last night. Full 'We get requests' album inadvertently and too lazy to pull the usb stick as it was in hibernate mode. On first listen it seems excellent.I thought noise floor was very low. It was late last night so could be just a good time to try it out. MQn I think might be more dynamic/lively sounding but will wait until I have tested more before venturing my view.
Hibernate with usb stick is a pita but the ability to play flac/wav all versions makes it easy to use.
I also heard that the sound signature of new beta 6 is heading MQN direction and that is more similar to it then to jplay 5.2. However had not tested it myself yet.
Tony I have a good news for you. You can use jplay in hibernate mode and still be able to play / pause / stop / and skip tracks :) without the need to wake it up. All you have to do is it to use foobar as front end for jplay and Foobarcon on your phone / tablet to control it (give you same functionality like jriver but it works in hibernate without waking up machine which jriver does not).
It of course require some kind of lan access. Either wifi or cable.
There is no much going on here lately, so I want to shake it little bit, to make an announcement...Haswell finally...:)
At the same time I want to thank to Ken and Nige for tremendous support in this journey. I'm not done yet with all the tweaks, but basic stuff is in place, I can play the newest MQn versions.
Cheers!
Cheers!
What have you done so far? Which tweaks have you used? I am asking as I am at similar stage as you it seems with Haswell build
Sent from my HTC One using Tapatalk
