lekt player
lekt
Re: lekt player
Post by lekt »
jesuscheung wrote:don't think changing affinity/priority helps...
yes. i see sometime windows is angry and SQ will become bad. not always as we want. multitask OS is too complex. may buy CDPlayer 10.000$, but i have only headphones 10$ now, hehe...
Re: lekt player
SetPriority.exe lekt dwm winlogon wininit low
(lekt=normal)
vs
set lekt to realtime
not sure which is better
Re: lekt player
seems better. no sideeffect of realtime. CD player sound kept
EDIT
change nothing best for me haha
Re: lekt player
lekt wrote:may buy CDPlayer 10.000$, but i have only headphones 10$ now, hehe...
i want your headphone!
imagine if you have a STAX, you can make everything correct.
Re: lekt player
love this 2.55
alright. best tweak is realtime + timerresolution=0.5ms. am surprised sound not intense. sound density +5-10%. mellow/airy kept.
maybe 2moro difference hehe
lekt
Re: lekt player
Post by lekt »
lekt wrote:
jesuscheung wrote:please make 352, 702 versions for 2.55
OK, will do. but number 256 better in my current algorithm. 352 maybe better with other method. will do.
made for you 2 versions 352. seem better. OK that can use old algorithm. the first i feel 352 more clean. try them.
uploaded v2.55 352, v2.55.2 352 for buffer size 352 frames.
Re: lekt player
2.55x 352
-with correct clockrate for 352. richer/cleaner/more power. stage size +0.5%.
-256 better soundstage. 352 soundstage incorrect for me.
-256 is musical. 352 no. hehe
thx
lekt
Re: lekt player
Post by lekt »
jesuscheung wrote:2.55x 352
thx
in my case 352 normal, as 256 (even better for some things). i use all default windows setting.
Re: lekt player
SetAffinity and SetPriority messed up things.
restart PC. 352 now ok. normal for me too. better better!
soundstage still feel different. different better or different worse? will see
lekt
Re: lekt player
Post by lekt »
SetAffinity and SetPriority maybe for testing only. better in normal mode with claen OS as you made.
found out new method in code, interesting. coding now, hope better will be soon.
