jkeny wrote:nige2000 wrote:
the storage usb3 is in a usb2 port but im still getting good speeds 80mb/s on a file transfer.
i have a preference for the usb 3 ports, my wtg is in one and the dac in the other,
id like to try all in usb3 ports but i have only two.
i might look at getting a pcie usb3 card so that i can disable the usb2 drivers as their affecting my latencymon results
Yea, but what I'm trying to ascertain is - if the USB 3 stick is responsible for the improvement or the USB3 port? You've answered my question, I think - you are using USB2 ports but you also say you prefer USB3 ports?
the kingston WTG stick works very well, stable and sounds better in a usb3 port, im assuming its to do with faster speeds and/or better/more stable power.
Even for non audio related stuff i prefer the usb3 ports over usb2, seems to preform better with usb2 devices.
so the answer to your question is both the usb3 port and the usb3 stick seem to be of benefit, id like to try with all usb3 ports, to see if there's another improvement. (this would mean i need 3 ports but i only have two ports)
the i7 build i have has 10 usb3 ports it would be perfect for testing alot of theories,
but with its current configuration its not at the races with my zuma type build or my i3 build with the maplin ps, and i don't feel like dismantling it to test a theory.
should be worth testing the kingston usb3 in the nuc, did u get the msata?
