lekt player
Re: lekt player
like 2.55 soundstage better.
Re: lekt player
2.55 has good depth image. 2.55.2 less.
Re: lekt player
2.55.2 has simple soundstage. also great.
not sure what is correct. headphone not good enough.
2.55 is first time i like 3D soundstage. shocked! first time 3D feels natural.
other software player 3D either only sounds ok. or unnatural
Re: lekt player
i feel v2.55 sound more like vinyl, treble not in high frequency as CD. v2.55.2 sound more like CDplayer, treble in high frequency, sound have more width/heigh. need more test.jesuscheung wrote:2.55.2 has simple soundstage. also great.
Re: lekt player
vinyl treble is better! many people love vinyl for this.
Re: lekt player
2.55 + my OS + perfect bios = no motivation to tweak.
just enjoy music!
maybe going to spend 20mins everyday to code a audiophile script. so, you can use it.
just enjoy music!
Re: lekt player
OK, think need script set priority. i tried set in .bat file but only high priority works, realtime does'nt work. think does'nt need set in code, let's user choose for use by your tool.jesuscheung wrote:2.55 + my OS + perfect bios = no motivation to tweak.
just enjoy music!
Re: lekt player
uploaded SetPriority.exe
https://drive.google.com/#folders/0B9ZK ... ERHWTJXYjA
usage:
SetPriority.exe lekt low
//try to set all processes to low priority except for lekt.exe
SetPriority.exe lekt restore
//restore all processes to normal priority. dwn, winlogon, wininit will restore to high. lekt.exe priority unchanges.
priority can be
realtime, high, abovenormal, normal, belownormal, low
may help SQ. maybe not. hehe
usage:
priority can be
Re: lekt player
don't think changing affinity/priority helps.
if processes have work to do, all this does is delay the work. work still needs to be done!
CPU=0% most of the time. CPU has too much free time anyway.
better tweak is to tell process NOT to work, or reduce its work.
change priority/affinity is just a quick hack. not proper. evil tweaks.
same as changing priority of IRQ, interrupt. better + worse.
better tweak is reducing the number of IRQ. e.g. disable usb. disable PCIe. etc
Re: lekt player
SetPriority works OK. but i think other method: set lekt.exe abovenormal/high/realtime, let's other processes normal work as they are, does'nt touch them. maybe your method better, keep lekt.exe in normal but others to low. there's we love playing in normal priority. sometime when windows is bad i will set lekt.exe to high or realtime, hehe... thx.
