lekt player
Re: lekt player
uploaded SetAffinity.exe. maybe helpful for you to test.
https://drive.google.com/#folders/0B9ZK ... ERHWTJXYjA
usage:
SetAffinity.exe lekt 0 0 1 0
this will try to set every process to cpu3 except for lekt.exe
this is ok too:
SetAffinity.exe lekt process1 process2 process3 process4 0 0 1 0
to restore to normal:
SetAffinity.exe 1 1 1 1
for i7
SetAffinity.exe lekt 0 0 1 0 0 0 0 0
for atom
SetAffinity.exe lekt 1 0
etc
i think
CPU0 = real core
CPU1 = HT core
CPU2 = real core
CPU3 =HT core
not exactly sure.
Re: lekt player
ok. listen more 2.55. bass too good. forgot treble. realize some treble tune incorrect. that's it.
not sure realtime is better. some better. some not better.
setaffinity lekt svchost 0 0 1 0 0 0 0 0 sounds ok so far.
Re: lekt player
uploaded 2 mods for 2.55
try
(mod admin stack heap 40 08 01 04)lekt.exe1644 v2.55 256
this one is interesting. more vibration i think. definitely more power.
lekt
Re: lekt player
Post by lekt »
jesuscheung wrote:ok. listen more 2.55. bass too good. forgot treble. realize some treble tune incorrect. that's it.
tried your setaffinity, usefull tool. will more test.
i remember, when use JPlay, JEP, SQ not stable, depend on how i made windows tweak, how turn on/off core parking, ?%CPU,... SQ always changed, today OK, tomorrow bad. maybe reason is affinity setting. when we force try to get exclusive or something of system resource, windows re-distributes resource in background for reasonable working, and regularly do this. sometime SQ changes in time when i have listening music track. strange.
but i think priority more stable. almost old MQn versions running with High Priority, SQ stable. realtime easily make intense, maybe not good.
Re: lekt player
imagine 1 change adds 0.3% SQ. fresh win8 install = 50% of max possible SQ .
100 changes = 50*1.003^100 = 67% SQ!!
you do few changes. not enough.
remember. 1 bad tweaks = -3% SQ. lol... very annoying.
Re: lekt player
i have backup image of my 2012 every month.
i can hear 5%-10% increase each month. been 10months i think.
so my SQ should be 50*1.05^10=81% of max possible.
lekt player adds 20%. so my SQ is 101% lol. joking.
lekt
Re: lekt player
Post by lekt »
jesuscheung wrote:...so my SQ should be 50*1.05^10=81% of max possible.
your OS is most expensive, hehe... nobody can make so much tweaks, also your careful learning of windows secrets. i has give up 6 months ago from tweaks, only coding now.
Re: lekt player
lol. very easy. in registry, search "enabled", you can find 1000 things to disable. in fact, only 10 things makes SQ better.
i don't have more tweaks. 81% is maximum for me i think. fixing my mistakes can add 5%.
did you know c:\windows\system.ini affects SQ. that's like for 16 bit applications/DOS.
lekt
Re: lekt player
Post by lekt »
not sure realtime is better. some better. some not better...
have detected "some treble tune incorrect".
uploaded v2.55.2 256 , fixed it.
- vibration a bit of bit better
- sound is rising up to enough heigh, expand to both left/right sides on every beat of rythm. now most left and right edges have sound (only expanding from center on every beat), very nice. does'nt need running in realtime priority
- vocal focus and focus of instruments sound exactly correct (or ~ exactly?), very clarity sound.
try it.
Re: lekt player
2.55.2 still a little off in treble tune. maybe worse. maybe buffer size maybe clockrate. treble is difficult to be correct in tune.
treble needs time to test. until ear soars and then i know for sure.
