wushuliu wrote:(Weird, I thought I responded, but maybe I dreamt it)
Correct per gstew. And no way I'm doing that mod to the Oppo, replacing the clocks was dicey enough!
Nige, do you think it would be worth it to add a flipflop to the wm8004?
bare in mind as i dont know what an oppo 103 is exactly need a bit more info
had a quick flick though the diya thread lots of good stuff but missed the i2s tapping bit
i see an audio output board, you want to replace that with soekris?
whats the audio signal coming in with that ribbon cable... spdif?
nige2000 wrote:hmm..
think i got your thinking
spdif out to wm8004 to reclocking flip flop to soekris i2s input ( flip flop clocked from soekris master clock)
keep all with good power and should be worth a shot
might be interesting test having the two audio frequency clks with a switch on OE
synchronously clocking the wm8804 and 574 ff
maybe it would negate need for ff ?
but probably not
otherwise use the soekris masterclock out for both
just a thought....
in a thinking out aloud type of way.......
Interesting. The WM8804 datasheet says this though:
In hardware mode, the OSCCLK
must be 12MHz and hence the external crystal (or applied XIN
clock) must be 12MHz. No other OSCCLK frequencies are supported in hardware mode.
