John Dot wrote:
sbgk wrote:
sebna wrote:Could the Single Device be set as start parameter so for example by executing mqn \\?\usb#vid_16d0&pid_071a#413-001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\wave
0
it would play device typed in instead of going through auto and at the same any device could be used this way as single device?
you would think that would be easy, but more difficult than you realise.
Is it possible to hex edit the MQn.exe and insert desired device name string? It could be very useful I think.
It is recognisable in a HEX-editor:
Code: Select all
\\?\tusbaudio_enum#vid_23db&pid_0002&ks#0208#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\pcm_out_02_00
0
John Dot
Post by John Dot »
@Aleg,
That's great! Now what's I need is to discover my device name. Can't manage mqndevinfo.exe to work - tried everything.
John Dot wrote:@Aleg,
you would also need the pin no
think I have a solution, just needs a bit more work
TioFrancotirdor
Post by TioFrancotirdor »
search for "tusbaudio_enum" in regedit.exe and you will find your device name.
Ubuntu Live USB in RAM
cvrle59
Post by cvrle59 »
Just listening aa-3/3.74 combo, the best I've heard!
cvrle59 wrote:Just listening aa-3/3.74 combo, the best I've heard!
for me the difference really comes across with live acoustic material
TioFrancotirdor
Gordon would you compile "mqnplay1644.exe 24 bit 8.92 avx2 dev tf 3" also?
Oh! managed to get my device no! The only defence I can offer is Gordon never said I needed the dac to be turned on!!
My excuse was ah feck it can't come up with a plausible one.
0
tony wrote:Oh! managed to get my device no! The only defence I can offer is Gordon never said I needed the dac to be turned on!!
0
am not doing any more dev builds, but looks same as mine so uploaded dev gk.
0
Thanks kinda guessed that as both my boards are amanero.
It don't make any odds but both unloaded versions are avx2 I am guessing it is a typo
