Aleg wrote:
tony wrote:Does anyone know a freebie Flac converter? Why can I never find the free ones?
Tony
Download the dBPoweramp music converter trial version.
After 21-days trial of full functionality it will revert to the somewhat limited free version. Conversion will remain if I understand correctly.
http://www.dbpoweramp.com/dmc.htm
dbpoweramp also allows tagging of wavs, worth every penny
sbgk wrote:
did you try the sse2 version ? that was my intrinsic version of no buff
no. and now trying. no sound into exception. bug.
-intrinsic does have cleaner audio than xmm. but the volume/weight is a bit much. less vibration too.
uploaded 2.64 sse2 v2 version
goon-heaven
Post by goon-heaven »
2.64 sse2 v3 best detail & resolution yet! Thank you. Havent tried other 2.64s yet.
2.64 sse2 v2, 2.64 sse2 v3
-both sound like other previous sse2 versions. sound don't spread as much as sse4. sse4's sound is like poison gas, it spreads everywhere.
-both sound good. top all other sse2.
-because sse2 sounds simpler. feels cleaner and clearer. feels more organized.
jesuscheung wrote: 2.64 sse2 v2, 2.64 sse2 v3
I know what you mean about the sse2's
But do you prefer it over the sse4's
yes.
edit:
i meant no.
Foobar alows you to convert from .flac to .wav. Its free.
http://wiki.hydrogenaudio.org/index.php ... :Converter
you will probably need to download a plugin and put it in the correct folder. I'm sure you will figure it out!
I use Foobar to convert .flac and .wma files to WAV. It works well and quickly.
Clive
Post by Clive »
My turn for a question. The spread / poison gas thing with SSE4, is this a lack of focus and does SSE2 give more central focus?
Clive
Post by Clive »
Me too, I converted 0.5TB of flacs to wav in one run.
