John Dot wrote:
sbgk wrote: can you remind me what your setup is and what was the last version that worked ?
PC: Win 8.1 x64 pro, cpu Q8400, 8GB Ram, Dac HRT Music Streamer II+, Asus Xonar Essence ST (the same since very first MQn versions) + head set/amplifier (I'm headphone guy).
Last working version was 8.16 and 7.44 earlier.
my KS Studio "log", hope this helps (working fine BTW):
think I see the problem, I've restricted it to render devices, but you just have audio devices, post the full name like mine above and I'll make a version to test if that's the issue.
Not that it is of much help, but I'm also not able to get recent MQns to work on my Win8.1 desktop while each version works flawlessly on my 2012R2 AudioPC.
On both machines the USB devices are shown as both KSCATEGORIE_AUDIO and KSCATEGORIE_RENDERER in the Categorie Aliases
m.massimo
Post by m.massimo »
jrling wrote:
sbgk wrote:8.77
8.77 Normal - Dynamic, clarity & detail in spades without harshness.
My new reference
I agree, better than 8.55 normal, my last reference
m.massimo
Post by m.massimo »
WaveIO
20141108 screen.jpg (95.56 KiB) Viewed 1143 times
John Dot
Post by John Dot »
sbgk wrote: think I see the problem, I've restricted it to render devices, but you just have audio devices, post the full name like mine above and I'll make a version to test if that's the issue.
That's excellent news.
Name of my device is:
"\\?\pci#ven_13f6&dev_8788&subsys_835d1043&rev_00#4&30d54f48&0&00f0#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\aa_wave"
m.massimo wrote:WaveIO
uploaded an mm version for your device, think there's quit an improvement in sq
uploaded a jd version
am trying to get it parameterised, but no luck yet. I'll do a few more fixed device versions because I think there is quite an improvement in SQ.
John Dot
Post by John Dot »
Report: no sound on mys setup.
m.massimo
Post by m.massimo »
Thank you, that's great, I'm going to listen it this morning (CET). I'll report asap.
m.massimo
Post by m.massimo »
no sound, unfortunately, but if I press the play button in KSStudio, the music flows.
If you're interested, this is the KSStudio log
https://www.dropbox.com/s/1dxwrpr3nl4ok ... o.log?dl=0
20141109 play.jpg (3.46 KiB) Viewed 1007 times
