8.70 >> 8.71
Noise floor us good in 8.70 compared to <8.64
Good detail and speed but seems a little dull needs dynamic definition/impact
is noticeable on piano
all in all good improvements
bad explanation drawing but have to try
Image[/url]
I think I need an explanation!
Also how are you measuring noise?
Jonathan
subjectively
is this where you harp on about measurements and blind testing?
nige2000 wrote:subjectively
Not aware that I have done so before, but am not going to do so now. Just wanted to understand what your graph was saying.
I do think that we would all benefit from understanding why changes made to the MQn code have an effect - both positive & negative, so that Gordon could be even more effective. But after a complete thread run by jkeny on this forum, I don't think anyone came up with any proposal for how to do the measurements.
sebna
Post by sebna »
nige2000 wrote:8.70 >> 8.71
Image[/url]
That is a very good visualization.
What I discovered recently is that I like version 8 for electronica where a bit of rounding and loss of texture is welcomed but WASAPi is still so much better on acoustic music like jazz for example.
Version 8 (have to check at which I have stopped recently) has more realistic soundstaging making objects more 3d and also projecting overall greater depth sensation.
ahh just what i meant about a lack of assertiveness in regards dynamic definition/agility and clarity
it seems a little smooth
highs and lows seem to be curtailed
yet some aspects of detail is very good maybe these aspects have not been revealed before in wasapi
because detail is usually curtailed when there is a smoothing effect and to some extent it still could be
i realise I'm explaining myself badly now
sebna wrote: What I discovered recently is that I like version 8 for electronica where a bit of rounding and loss of texture is welcomed but WASAPi is still so much better on acoustic music like jazz for example.
yes wasapi has a very realistic sound staging and texture with pin point accuracy as you say
cvrle59
Post by cvrle59 »
You must have your favorite wasapi version. I am wandering what that is?
uploaded 8.73, maybe better detail
interesting discussion on
http://www.diyaudio.com/forums/pc-based ... ost4112228
posts 81 to 84, never seen that discussed before, implication seems to be that 48 hz is better than 44.1
8.16 avx2
Which is 4kb
current ks is 104kb
maybe that's a factor
