Power Inspired AC Regenerator
Re: Power Inspired AC Regenerator
Aleg wrote:These things are sound killers.
Bad, bad, bad
if it is... I'll unplug it.
A monster box arrived today
Unless it needs lots of burn in for my amp
it will be used on my pc :(
Might pop the hood see what's in there
nige2000 wrote:A monster box arrived today
I just hooked mine up. Showing a steady 235 :) No sound quality issues so far but the tubes aren't even warmed yet. Nice simple design, with my chunky mains leads I'll have to raise it a bit but that's ok. Does what it says on the tin.
Yea dunno def flattening the sq here
Only spent 15 mins testing so it wasn't even warm
But I did fire some bass reliant tracks at it
nige2000 wrote:tested again this morning and im still of same opinion
I couldn't really hear a difference but will run some reference recording through it tomorrow evening. If it does sap the sound then it's onto the PC with it... At least it's shown me voltage at 235 - 240 consistently.
You might want to try pixresizer there Nige
Ivor wrote:You might want to try pixresizer there Nige
yea flickr changed there setup im still getting to grips with it
if i use pixresizer i lose resolution?
on tracks that have a large soundstage it is less with the power unit,loss of clarity, dynamics, bass control
that been said it certainly isnt blatantly obvious or a big drop in sq by any means
it could go unnoticed without a few cross comparisons with selective tracks
just doesnt hold the your attention as well
didnt try the pc on it yet
doubt it will have any effect with all the batteries
but ill try later
It's possible to still get smaller versions via flickr. I did it recently (eventually) but it wasn't as intuitive as before.
I forget how pixsizer handles res but I'm sure they would be easier to view and load if smaller... might be an ok trade off. Sur' try it and see!
On the sound quality... if I even suspect there's a negative effect it will be taken out... I didn't spend silly money on hifi to be sitting there wondering if I'm getting all I can get or not!
ok figured it out
its a pita will do it later
testing stuff is a bit of a compulsion here so im pretty sure its doing harm, but then again if i had terrible dirty mains i might have been delighted
ill likely use it on my pc
