Don't know if you have SBGK's permission to mod his code, but this one sounds fantastic!jesuscheung wrote:8.16 orig finally works ! overall sound is greatsima66 wrote:With all due respect for the Gordon's hard work and everybody else's opinions, I must say that either is something wrong with my system, or with myself, but I still can't hear the details, the clarity and the balance of 5.14 in the KS, including the latest 8.16's!
needs more decay
uploaded MQnPlay1644.exe8.16 orig MOD20
https://drive.google.com/?usp=folder&au ... 0plZTNGd0E
PE mod.
agility better. fast notes better.
did try tighten sound further my machine cannot handle.
Re: MQN 8.16 normal orig
7.41 normal (pa93) > 8.16 normal orig on my system
Less transparency and detail; triangle is getting lost in Griegs "Anitras Dance"...
Good news might be that Gordon might know now why the actual versions don't work with systems like mine? Hope is growing ;)
Thomas
Thomas
John Dot wrote:Don't know if you have SBGK's permission to mod his code, but this one sounds fantastic!jesuscheung wrote:8.16 orig finally works ! overall sound is greatsima66 wrote:With all due respect for the Gordon's hard work and everybody else's opinions, I must say that either is something wrong with my system, or with myself, but I still can't hear the details, the clarity and the balance of 5.14 in the KS, including the latest 8.16's!
needs more decay
PE mod.
The JC-Mod is not capable of showing details in high frequencies like delicate cymbals playing with brushes.
It gives a strange distorted kind of sound instead of clear cymbal brushing.
Win10 version also doesn't make to the regular avx
yes, that sounds about right. jitter is worsened.Aleg wrote: The JC-Mod is not capable of showing details in high frequencies like delicate cymbals playing with brushes.
is the MOD too tight sound? can loosen it.John Dot wrote:Don't know if you have SBGK's permission to mod his code, but this one sounds fantastic!jesuscheung wrote: PE mod.
some setups(aleg's?) need less tight sound they cannot handle it
guess is the same idea as lowest buffer not all setups can handle
Not a recommended MOD if it increases jitter.jesuscheung wrote:yes, that sounds about right. jitter is worsened.Aleg wrote: The JC-Mod is not capable of showing details in high frequencies like delicate cymbals playing with brushes.
wait me... let me mod 8.16 avx2... is this the version?nige2000 wrote:8.16 avx2 mod would be more useful
what is it a 64?
i mod based on how tight my setup can handle...
the original size for 99.9% of software is 1000 hex stack commit size
half = 800
half again = 400
....200, 100, 80,
until 40 my setup cannot handle it with mqn...
the effect is similer to lowering buffer size
basically smaller = tighter sound
shall mod this 8.16 avx2 later
am busy now
the effect is 100% better for piano notes. it needs agility and speed.
for vocal, could be worse(or better in my case), depending on how crap is your OS
think this mod needs tuning based on individual setup....
please learn PE mod... do it yourself
JC posted elsewhere
I want more agility and not less.
This is not a direction I would want to go to.all earlier MODs use pkshan stack heap.
i feel that his mod is tuned for long duration note body, e.g. violin, vocal.
cannot handle fast notes with accuracy. agility is always lesser.
JC,
I must have missed the "PE mod".
Is this referring to PROCESS EXPLORER?
If so, that is a great introduction into registry reduction. And can be a great way to destroy an installation, too.
What was the MOD?
What was the MOD?
