i actually don't know hehehe. that "old" control is around 233KBClive wrote:There was a 3.65 but it seems to have gone now.jrling wrote:What new MQnControl? 3.64 is still the last one and has been for ages?btw... 7.46 sounds better now... new mqncontrol helps a lot
(bass was too tight. now bass is just fine)
the "latest" control is 240KB. this is the one i am using
me tooJohn Dot wrote:Still the same. No sound.sbgk wrote:uploaded 7.57 avx2 and normal, might fix issues for some
7.55 1644 avx2, a bit of clipping and crackling, but sounds the best! :(
7.57 2496 avx2 is to soft compared to 7.54 26/96 avx2.
7.54 26/96 avx2 has best details and dynamics........... from the 24/96 versions.
Still can't understand how avx2 is working for you Adam. I remember you advised me on some settings but I never got any avx2 to worksima66 wrote:7.55 1644 avx2, a bit of clipping and crackling, but sounds the best! :(
and I don't think anybody else with our intel board has managed to.
Update: Tried avx2 and seems to work. Checked in task manager to see what file is running. Looks like the avx2. Has anybody else got
this to work. Have I just got this mixed up again with avx??
You probably may not hear for a "special edition" yet...:)))tony wrote:Still can't understand how avx2 is working for you Adam. I remember you advised me on some settings but I never got any avx2 to worksima66 wrote:7.55 1644 avx2, a bit of clipping and crackling, but sounds the best! :(
See, Tony, the trick is to try! :))))tony wrote:Still can't understand how avx2 is working for you Adam. I remember you advised me on some settings but I never got any avx2 to worksima66 wrote:7.55 1644 avx2, a bit of clipping and crackling, but sounds the best! :(
There was one short period when I could not play the avx2's, but so far I don't have a problem. Maybe I'm running another "hybrid"!!! :))
I believe that has to do with CPU, not MoBo.
George is using also Ivy and play with no problem.
