jesuscheung wrote:.... not working here...
might be because your device name uses unicode characters, non unicode sounds better
DJ le Roi wrote:
DJ le Roi wrote:7.52 24/96 and 7.50 16/44 work both with my Teac Dac and my M2Tech Dac (Xmos). Beautiful sound.
Unfortunately, 7.55 is not working:
-Teac Dac: no sound at all
-M2Tech Dac (Xmos): crackles.
Tested it with two computers, same result. I use MQNLoad.
I think it has something to do with MQNLoad. When I first choose 7.49 and after that I choose 7.55 then it's working. Not tried hirez.
sometimes mqnload uses the previous version of mqnplay, are you sure 7.55 is playing now ?
3daudio
Post by 3daudio »
7.49 normal sounds great, just breaks up irregularily...sometimes after one song, sometimes I can play a whole album....
7.55 normal only gives distorted sounds...
Soundwise...You are definitly on the right track here, Gordon. Stability...?
3daudio wrote:7.49 normal sounds great, just breaks up irregularily...sometimes after one song, sometimes I can play a whole album....
any problems with 10ms period size before ? not had these problems so difficult to fix.
3daudio
Post by 3daudio »
no.
hmm..... how can i fix that...??!
7.46 works!
7.49/7.55 not work
btw... 7.46 sounds better now... new mqncontrol helps a lot
(bass was too tight. now bass is just fine)
Clive
Post by Clive »
7.55 working fine here.
What new MQnControl? 3.64 is still the last one and has been for ages?
Clive
Post by Clive »
There was a 3.65 but it seems to have gone now.
Yeah I remember that but I think it was for a special test that Gordon was doing at the time.
Going to try 7.55 (Normal) tonite. The SQ from KS is getting really, really good and I suspect that Gordon has more to come as he navigates his way through KS.
