Nigel, can you please compare the 24/96 versions.
Which versions to which versions?sima66 wrote:Nigel, can you please compare the 24/96 versions.
I know there's not that many but still
All 24 bit mqn wouldn't be as well optimised as 16 bit
But I think 24 bit has much more potential and scope than 16 bit had
Makes me wonder if converting all to 24 bit should be an option?
Your favourite 24/96 WASAPI to the latest 24/96 KS.nige2000 wrote:Which versions to which versions?sima66 wrote:Nigel, can you please compare the 24/96 versions.
I found that 5.14/2.97 in 24/96 to be better, but not on 16/44!!!
I have never liked any hirez version as much as I have 5.14 or even more 7.41/91 for 16/44. I probably didn't give them enough chance, so I have focused to dsd instead, in hirez domain.
found a few more settings
uploaded portaudio v92 with different buffer sizes
0.01 s
0.001 s
1 s
5 s
the 1s and 5s take a while to start playing. 0.01 sounds best to me, well better than 0.001 which sounds digital. didn't test the larger sizes long enough to decide on those.
0.01 s
0.001 s
1 s
5 s
sbgk wrote:found a few more settings
0.01 s
0.001 s
1 s
5 s
0.01 >> 1=5>>0.001(crackles)
Aleg wrote:sbgk wrote:found a few more settings
0.01 s
0.001 s
1 s
5 s
V91 >>> v92 0.01
