OK, will try that..... its 5.14 from what I can tell.
the next level has been reached
uploaded pa v91
you'll need to alter the device no in the mqnparam.txt file
mine used to say 1 and 4 and I used 4 as 1 was the laptop, though can't seem to play via the laptop.
now I use 0, is it because I have only 1 device that works ?
the reason for the change is that before capture devices were considered as well as render. now only render.
anyway, if you get it working it's a treat
cvrle59
Post by cvrle59 »
0 device works here too with v91...pretty good!
Actually, the best, I've heard so far!
cvrle59 wrote:0 device works here too with v91...pretty good!
+1
Better focus and even tighter bass.
Question: Why the MQn window doesn't close after the song is finished?!
satshanti
Post by satshanti »
Haven't had much time lately so I can't keep up with the speed at which new versions are appearing, but I noticed an interesting snippet:
sbgk wrote:uploaded v89 normal for those in the cheap seats.
there is an avx setting I could try as well, but avx2 is definitely better than normal.
With wasapi on my system with AMD CPU there was a clear order of preference when comparing the same version in the various instruction set iterations:
avx amd > avx > avx2 >sse2
Now that you mention an avx setting you could try, I wonder if that would still improve things with KS over the normal versions for the folks like me that can't play avx2.
I also would like to request a 2496 normal version of MQN 7.41 if possible.
v91 better. bass control is superb here.
probably can retire wasapi now?
jesuscheung wrote:v91 better. bass control is superb here.
v91 is very good and enjoyable great progress,
takes longer to test now (good sign)
resolution/detail/focus, dynamics/definition still a little behind yet
other stuff ks does better?
KS is going to be great :)
is reducing the buffers not gonna help the resolution?
still think the kernel is trying to handle 10ms of data at a time. Did try smaller buffers, seemed noisier to me and there was loss of bass.
Same with wasapi lower buffer less bass quanity
I haven't been testing all the versions
Which are low buffered?
Think low buffer and try to find another way to get the bass back should be an option
lowe
