v89 better.
does v89 seem to tight?
jesuscheung wrote:v89 better.
PA 89 good step forward
Peg in the ground moment
Is PA 89 now at a level or surpassing previous MQN non PA versions?
nige2000 wrote:Yea it's more likely to be a mobo CLK
But which one the usb clk the mobo master CLK or the realtime clk
Because their replacement all provide a similar increase in sq
But I never got the three replacements to work simultaneously well not reliably anyhow
I believe jitter in timing has a knock on effect
Oh, I thought you had replaced the 3 clocks on your mobo, successfully? (after a couple of "puff the magic dragon" moments) :)
Nope
Not surpassed wasapi for me yet
Resolution dynamics definition not just there yet
Well ive the 25 mhz main clk the 32.768 kHz realtime clk and the 24 mhz usb clk on the usb card done
I failed to get the 24mhz operating system clk working reliably
Though it did sound awesome
v90 might be better in that regard
For me v89>v87 because it is tighter. By that I mean tighter bass which surely is to be desired? v89 also brought a more defined upper treble which v87 lacked slightly.
v90 just loosened the bass.
v89 is my new reference (with 7.41 Normal).
Yea that's what I thought too
I'd but too tight in the same category along with too much accuracy, money and sex
OK lads,
I've lost track of this over the last few months - been working hard on other stuff. Now its back to some CA catchup time.
I'm back on a version of MQn from earlier in the year - I think its 2.73 and running server 2012 on a zuma PC with some separate PSU but not as good as it could be. I'd like to be able to play 24/96 etc. What is the correct newer version for me to use?
fran
Fran wrote:OK lads,
fran
did you try that one from tuesday?
might need to fiddle with run with admin rights on the control file
i doubt the one im using will work on the intel h77 board
think adam posted a link to his 5.14 avx2 few pages back
the ks is getting good too
