sbgk wrote:pa v84 worth a try
Did you figure out what is going wrong with the copying of mqnplay2488.exe?
DJ le Roi
Post by DJ le Roi »
I tried 3.64/7.41avx2 in combination with PA84. All bitrates 1644/2496/2488/24192 works fine with my M2Tech Hiface Dac.
With my (problematic) Teac Dac there is an strange problem. It works very good for 20 seconds and after that: heavy distortion. What can be the cause? Buffer Size?
PA 85 was a step backward, that change didnt work
uploaded pa v86
how it gets better than that I don't know
yes, didn't have system("copy mqnplay2488.exe mqnplay.exe");
Aleg wrote:
And maybe 176.4/24 as well so there is a basis for DoP support?
how's that going to work ?
need help in understanding the format, asked before and didn't get any, also can't test it.
DJ le Roi wrote:I tried 3.64/7.41avx2 in combination with PA84. All bitrates 1644/2496/2488/24192 works fine with my M2Tech Hiface DAC"
I see DJ le Roi has all flavours working including 24/88, is there a corrected version of 24/88 somewhere that I missed ?
Normal ones as well maybe??
think he must be imagining things
uploaded v86 no wt version, avx2 only - wonder if v86 sounds congested, this one is more open.
